piston rings
Results 1 to 14 of 33
piston rings
    Senior Member CHEVY JET's Avatar
    St. Charles, IL
    Default piston rings
    Im Sure Its Been Mulled Over A Ton...... But I Dont Know The Anser, So Here It Is. Do I Gap The Rings Differently For A Jet Compared To A Car. If Yes What Do I Gap Them At. I Have A .030 Over 454, With Srp Forged .200 Dome And Total Seal Rings Prt #cr9190-35. I Stuck A Ring In The Cylender And It Had A .015th Gap From The Package. Whare Should I Gap Them???? Thanks, Don
    Newton Ks.
    Yes, and no.
    You can gap them tighter in a thermostat-regulated car engine, because thermal expansion of the parts is more uniform and controlled.
    You do not have to gap them especially wide.
    GM's own high performance use spec for the Big Block is .022" top, .016" 2nd, .016" oil rails.
    The 2nd ring doesn't get nearly as hot as the top one, so expands less.
    I would personally gap it very closer to the same as the top, to avoid pressure build-up and resultant flutter.
    Open that top ring up a little, get it to .020" or a tad more, and it'll be fine.
    H.L. Mencken
    The latest trend on the second ring is to open it up a few more thou, than the top ring. Once it's past the top compression ring, it's done....it's not going to combust, or make you any more power. Opening up the second ring let some of the pressure out of the between the rings, and will reduce any chance of ring flutter.
    Colorado Springs
    Quote Originally Posted by CHEVY JET View Post
    My last set of sealed power rings stated that a larger second ring gap helped the top ring seal better. So I gapped my .030 over 454 at .019 to .020 top(I added a thousanth) and .023 second. That gap was based off their marine recomendations. Keith Blacks/Silvolite has an interesting article on ring gaps and experements with the fact that a .030 ring gap will make the same power. Cylinders don't expand as much in a jet since the engine doesn't get very warm so you have run more gap and piston clearence than in a car
    visit JE/SRP and Total seal's website. lots of info there
    here is a link to 4032 pistons
    http://www.jepistons.com/dept/tech/d...instrc4032.pdf
    #55
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I was just going to start a post about this... My pistons are coated mahles though. I remember back on hotboat there was a topic started about this with opening either the top or bottom (think it was the bottom) to help reduce ring flutter and to increase performance.... Were all you guys at that discussed this
    Tri-Cities, TN
    Shaun,
    Yes more gap on the second. For your build I would open the second ring up about 25% more then the top ring.
    Oh yeah, how do you like those Mahle pistons?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    San Clemente, Ca
    Shaun,
    They are nice! I've got pictures of everything going to start posting here soon. What do you think i should start with for the top?
    This will probably get slammed and thats okay! Coming from an ol guy that worked for sealed power for a few years the rule of thumb on ring gap is .004 per inch of bore. So do the math. Now I will admit that is closed cooling system data and heat disapation on a marine or fresh water system will vary. then If you toss nos into the mix things and specs will change even more. The worst part is ring flutter and gaps butting heads. Sleekcrafter is correct on opening up the top ring to help the second ring get a charge of help to seal. If it were me I would gap the tops at .022 and the second at .020 in a marine app w/o nos. With juice that is a wide open thought cause you're tossing a MAJOR coolant that will close gaps in a heart-beat by decreaseing expansion rate in a micro second. I am no nos fan and self admitted ignorant to its effects on a motor. But I have read in these forums that if you run to tight with nos you will get serious ring butt in a hurry! M
    Tri-Cities, TN
    Every piston mfg is different. Follow what Mahle has in there instructions on ring gap for your application for the top ring.
    Chris Straub
    Straub Technologies
    Tri-Cities, TN
    Ol Guy,
    Did you know the "Mad Scientist"? Barry Robotnic?
    Chris Straub
    Straub Technologies
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Ol Guy,
    lol!!!!it has been known for sometime that opening the 2nd 1 up further helps with ring flutter.i just filed a full set of speedpro rings this weekend.bbc style.
    it states in there instructions to open the second ring up alittle further than the top ringwe did .028 on the top and .030 on the 2nd this is what it said for nos instructions/with forged speed pro pistons.travis
    Old Timer LeE ss13's Avatar
    San Dimas CA
    Childs & Albert Zero Gap 2nd rings. ZGS.
    I don't know what I don't know because I forgot !!!
    Quote Originally Posted by Freedom Child View Post
    They all look alike upside down
    Quote Originally Posted by Wannabe View Post
    A grace of the English language that you obtain simply supersedes all reasonable expectations.
    Ol Guy,
    Yes I do!!! He talks to me as I am building my motors I have ran this question by some "others" and will give you a shot! Have you ever seen a lifter explode in the bore, I have one and took it to my grinder yesterday for his opinion! The guys I have sent P.M.s to are baffled. Let us (me and the mad man)hear from you. M
