Nicks in Piston
Nicks in Piston
    Just Me snoc653's Avatar
    Eastern Iowa
    Default Nicks in Piston
    A guy has a 454 long block he wants to sell me, that came out of a boat. It was supposedly professionally built and the the boat repo'd by the bank. This guy pulled the engine and found small nicks in the top of one piston and put another engine in the boat. He's asking next to nothing for it, so I was skeptical. The marks look like someone put a long reach plug in it and broke the electrode off. It has a lot of good stuff in it, so I'm going to get it no mater what, but would you run it with maybe 10 small nicks in one piston?
    The 4 bolt block has been decked clearenced for the valves and heads have roller rockers, guides and studs and big valves. I'm guessing it will be in the 11:1 compression range. I need to pull the cam and check specs. I'll post pics when I get it home.
    waterloo
    Yup.... run it.
    Wags
    Senior Member bville's Avatar
    Sep 2009
    Glasgow, KY
    Agree just make sure there are no sharp edges,if so just blend them in.
    Eastern Iowa
    Thanks. I picked up the engine and it looks like the piston will clean up and be good to go. They are stock 3999295 pistons, so if I don't like how they clean up it shouldn't be hard to find one or more.
