procomp heads
Results 1 to 6 of 6
procomp heads
    Default procomp heads
    as any body ran any of these heads yet and how did u like them
    Quote Originally Posted by 496 river rat View Post
    There have been plenty of discussions on these heads. In a nutshell, you'll get what you pay for, and in reality, for not a lot more, you can get a lot more. It's all relative to your goal, and what you have to spend.
    El Cajon, CA.
    Subject has been beat to death, try a search, I ran them last year out of the box with no problems yet. There are many china made parts haters on here. Impatient 1 has run them as well. You're probably going to have to run non-stock parts so get them bare as a lot of Pro Comp hardware doesn't work with other ProComp hardware. You'd be lucky to buy one head of the competitor's for the price of a pair of Pro Comps, unless you buy a Pro Comp copy because it's not from China. The competitor's head's will also need other hardware.
    If you can afford to buy a better head, buy a better head as they are for the most part out of the box as advertised. If you can not afford the better Aluminum head, invest in a good iron head. Unless you are an engine machinist, and can do all the work your self, you will find the Pro-Comp heads will come up way short of your goals. People will tell you they work fine, but don't short your self to be lackluster
    Cantard 71hallett's Avatar
    snow bank
    Maybe a set of Patriots? Near the same money....little better.
    Actually a decent head IMO.
