PSI screw blower
Results 1 to 6 of 6
PSI screw blower
    Senior Member ps 14's Avatar
    Peoria AZ
    Default PSI screw blower
    Need intercooler for PSI screw bolwer
    What is everyone running
    Jan 2012
    lake Charles, Louisiana
    I used a lee on mine, had to make some plates to seal it top and bottom, used some 1/8 aluminum. Superchiller or Blower shop, or Whipple would work fine also.
    I have plates I'm not using if you have a intercooler.
    Cleanest deal is the Whipple intake w core inside, plus it's 2" lower
Name:	psi, intercooler.jpg
    Sep 2010
    I have looked at the whipple intercooler that they use on the quad rotor setup. It looks like that core would restrict the flow . Has anyone compare that style intercooler to the taller ones that are used on top of the intake manifold ? GD
    Jan 2012
    Yes, I saw 1 lb difference top to bottom on the dyno, at around 18 lbs. Now this was the full size core, not the large MOAC one.
    Never dyno'd the superchiller to compare though
    Peoria AZ
    Default Plates
    Do you have any pictures off the plates
    Quote Originally Posted by SHAWN DAVIS View Post
    Jan 2012
    Nope, they aren't anything special, cut to seal a couple small gaps around the cooler opening
