manifold restrictor inserts
Results 1 to 8 of 8
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default manifold restrictor inserts
    I got these with a fel pro gasket kit i bought way back... didnt use half the stuff in the gasket set... One thing it has is a package that says manifold restrictor inserts, they are probably 1"x1" and thin metal and have a hole in them... What are these for? I'm guessing to restrict the cooling system up into the intake manifold?
    The Man cordog009's Avatar
    East Texas
    Probaby for EGR ports in the heads.
    1984 Youngblood TX-19 SOLD
    To block exaust crossover in the intake, I use a piece of stainless, block it completly. In the center of the intake right?
    San Clemente, Ca
    Ahh, you know your probably right. They look like they would fit perfect here... My restrictors have a hole in them.. guess thats why they are called restrictor inserts and not blockoff inserts
    You don't need them Shaun, your T Ram doesn't have a cross over passage. If you like, you can install them, put a little silicone in the restrictor hole. Might keep your T Ram from getting carbon on it where it lines up with the cross over ports.
    San Clemente, Ca
    ya, dont need em with my manifold. My cometic intake gasket covers it anyway... so the manifold will stay clean
    Newton Ks.
    Yep, exactly what they are for. Pretty much stock aplication only for under-carb manifold heat, for emmissions and cold weather driveability.
    Very few aftermarket manifolds even have the crossover passage.
    H.L. Mencken
    Default "heat riser"
    With tuned, open exhaust, the amount of exhaust crossing over would be minimal anyway. Even a stocker needs some sort of restriction to force exhaust through the intake, like the old heat riser, spring loaded, flapper just before the head pipe connection....Damn I feel old knowing that..........Ray
    LOUD BOATS SAVE LIVES
