better exhaust
Results 1 to 8 of 8
better exhaust
    Peoples democratic republic of California
    Default better exhaust
    Hey guys I have a eliminator barge 21' two step deck daycruiser that according to professor Greg Shoemaker has a 454 engine that has a rated output of 450 hp. The professor tells me that I need better exhaust to get any real performance gains. the old cruiser can hit [email protected] rpm now. What performance exhaust can I fit into the 33" wide motor box?
    Southwest corner AR
    I would talk to the guys over at Lightning! They have jackated headers that should wake it up! Good luck WT
    WT
    WFL Crew!!!
    New here Beer:30's Avatar
    Bakersfield, CA
    X2. Tubular-style will have the best cylinder scavenging.
    Bakersfield, CA
    Default Lightnings
    Here is what they look like:
    Southwest corner AR
    What are you running now? Logs, Upsweep manifolds, other? WT
    WT
    WFL Crew!!!
    at the moment I have the stock Glenwood thru hull logs
    Southwest corner AR
    Yes you do need more! I think an upsweep manifold would help some but not as much as a set of lightnings! WT
    WT
    WFL Crew!!!
    Newton Ks.
    My 454 had stock small-valve '049 heads, a .565" x 280* dur hyd cam, and Edelbrock performer RPM Air Gap manifold when I took off the Niccson logs and put on the Lightning Headers (Jacketed, thru hull (look at my avatar).
    Gained 200RPM on a Berk A-cut (Aggressor B).
    Then I had the heads ported and valves enlarged, and gained 400RPM.
    H.L. Mencken
