How do these dyno numbers look?
Results 1 to 14 of 39
    Southwest corner AR
    Default How do these dyno numbers look?
    This is a 496 that I built on the mild side for a jet! I was posting these dyno no. to see what you guys think! And how well you think it will push a 19' simi-v jet boat! Put out some MPH no. ET's ETC! WT
    [IMG][/IMG]
    WT
    WFL Crew!!!
    ok, post the numbers too cause ya know all i see is red x's
    Southwest corner AR
    LOL! Tom I will send them to you!
    WT
    WFL Crew!!!
    got em, that otta get r done becareful letting outta that thing
    Southwest corner AR
    It has the best shut down I have ever seen! I have not got it to fly high enough yet! Next step! WT
    WT
    WFL Crew!!!
    yeah, so did my sj till i pulled out the 450hp mill and dropped 850hp on bottle into it them 80mph+ lh 90* turns are skeery
    question is; Are You Happy???
    #55
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I'm curious what type of components?
    Southwest corner AR
    I will let you know Thursday! Test this eve. I already know the pump is a little tight! WT
    Componets 454 4 bolt SRP 10.1 pistons with 119 CC pro comp heads Scat 496 rotating ass. 6.385 rods 4.250 stroke crank Chris Struab profile Bullet solid roller cam! I don't have the no. on it with me but it's around @ 50 250 in. 260 ex. 677 in.lift 668 ex. 1.8 in. 1.7 ex. rockers Brodix Dominator intake with an adaptor for a 4150 850 Chuck Nuytton modified carb! WT
    WT
    WFL Crew!!!
    Southwest corner AR
    If you remember I was looking at a red and white Condor!!!
    WT
    WFL Crew!!!
    you should see it now, josh has really pimped it out nicely. has a completely polished pump and new trailer under it now along with a few other goodies.
    724hp on pump gas with procomp heads, man you know that's not possible with those heads wonder what my 505 was making , it was basically the same motor but at 13.5 to 1.
    Southwest corner AR
    Yes I know! He sent me a pic. last week and it is shinny and pimped! You know pimpin aint easy!!! LOL!
    I would est. 775 or so my last 505 13.1 motor full race went 805 on the dyno!
    WT
    WFL Crew!!!
    Senior Member Notalent's Avatar
    Dallas/HB/LBC
    VERY NICE NUMBERS!!! Makes me even more eager to see what my 496 is gonna put out!!!! Crank and Rods get her Wednesda
    "Pain is a figment of your Imagination"
