gasket or no gasket
Results 1 to 9 of 9
gasket or no gasket
    Douglas, MA
    Default gasket or no gasket
    Should I use exhaust gaskets on this or not?
    I always just went with hi temp silicon.
    Cantard 71hallett's Avatar
    snow bank
    I have always had far better luck with stock type gaskets with a little high temp on them over header gaskets. (like you get in a rebuild kit or at any parts store)
    Senior Member ovrkll77's Avatar
    CALI
    gaskets
    Morgan Hill
    There are two problems.
    1, there are two completely different metals with two very distinct expansion rates. (stuff's gonna move around)
    2, there are dissimilar metals offering up galvanic opportunities (corrosion)
    I would recommend fiber (no foil) gaskets, or copper gaskets for headers with just a touch of Ultra Copper silicone, it's always worked for me.
    GT
    GT
    Senior Member KLINGER's Avatar
    redlands/ aha quin
    gonna need more pics of your setup to advise
    Douglas, MA
    Quote Originally Posted by KLINGER View Post
    soooon!
    Hoping to get a little further this weekend on it.
    redlands/ aha quin
    I just picked up my rayjays from being rebuilt at performance techniques in san bernardino and plan on putting my banks kit together soon as well. i would like to see more pics of these set-ups for plumbing etc...
    Douglas, MA
    I will certainly keep you posted.
    The water is pretty straight forward...I use a pick up under the boat for the intercooler which will dump into the exhaust pipes...the oil is a little trickier, I got a remote oil filter which splits off and goes to the carb box (which when you think about it is kind of dumb). from there it feeds the turbos...then the oil drains from the turbos to the mid/front of the oil pan.
    redlands/ aha quin
    yea i could kinda tell thru the pic on the oil drain. what about the fuel system and the carb set up? i've got an 850 that needs to be gone thru but im not sure where to go with the set up on jetting etc...
