E85 - Alky ....On D'Fence y'all
Results 1 to 14 of 30
    Member Gopher711x's Avatar
    Jul 2016
    In a van...... down by the river
    Default E85 - Alky ....On D'Fence y'all
    Seriously thinking about going with a Hat and dropping the carbs . My question is stay w/ e85 injected or just go alky ? I tried to stay with e85 and be able to do some lake cruising but the fuel efficiency is just not what I expected and I probably burn it at a close ratio to alky anyways . So question is to you guys that have Race/Lakerods that are running a Hat and still seeing dual usage , what are the pros and cons ?
    I know the hat will be touchy on throttle , and I'm looking at a B&U Hat with the progressive linkage . And I know there is probably a bit more HP to be gained safely on a straight methanol tune ?
    Talk to me Guys and Gals
    It's me Gopher711 that's been on here for many years till the site got hacked , just added the "X" behind my old name
    Tower Park Resort, Lodi, CA
    Shoot man, I haven't used either. Got nothing for ya but a stinky pile of opinion. How'd the boat run this past season?
    Peoria, AZ
    I put a big injector (the competitor to Enderle's big and ugly) on a NA Chevy and the throttle was twitchy. It was a drag only deal so I could live with it. I don't know how the progressive linkage will feel. I know that for basic driving I would not mind progressive linkage for a standard bird.
    If you were burning close to as much E85 as you would alky then something was wrong, or you are under estimating how much alky you will burn. I love injection, but I don't know if I would do it. I have done stacks, and will do them again, but not sure about a hat.
    Paul
    Sep 2010
    I ran the old style 4 port hilborn injection on a blown motor and loved them ! The only draw back for me was when I wanted to ski that the person driving had to know what they were doing. I made a water pump that had a drive for the pump that was low in the boat and never had to prime it to start. Going to put them back on the new motor as I love the throttle response !
    GD
    Whitewright, TX
    Quote Originally Posted by HPbyGD View Post
    GD
    Here's a pic of Gary's boat taken in the early 80's. That boat and powerplant was a great ski boat. He ran a 45 gear in it so it cruised awesome too. And no.....that's NOT a BBC, but a 429 FORD. Gary didn't mention that he ran that 4-port on gas which is a bit tougher to maintain a tuneup with varying air conditions. E-85 Is waaaay easier, so my old nostalgia Kindsvater is getting an 8-71 with E-85 QuickFuel carbs too! Jocko
ID:	933242   Click image for larger version.
    Sep 2010
    @ Jocko great memories at the Skylark !
    Jul 2016
    Seth , Boat hammers it hard
    with only 6# boost spinning SS"A" impeller with HM inducer and stuffer plate to 6800
    so far tune up looks to be spot on and has not been pushed for max performance yet . Motor is cammed to make peak HP in the 7400ish range
    plans are to replace Weiand 8/71 street blower with a 10/71HH before I lean on it any further , I don't like pushing cast rotors any harder than it is now
    but yea, I'm very happy with it and hopefully will hit Marble Falls race next year to get some hard data
    Carbs are ok but I'd like to have a more consistent platform and easier to tune , that's why im thinking about a hat
    i wanted to do a dual purpose race / lake rod but just doing a little hot footing and cruzing , it loves e85 ...I can go thru 10 gallons in less than 4miles matter of fact I just picked up a 8gallon race tank to mount in front of engine as a "reserve ". Tank that gives me approx 26-28 gallons total fuel cap. That's why I say I don't think it would burn that much more fuel on alky ...it sucks e85 at almost twice the rate it did on gas
    Jul 2016
    Jan 2012
    lake Charles, Louisiana
    Big and Ugly on mine, not a whole lot of river cruising, but hitting a wake sure makes it interesting! I'd skip the progressive linkage myself
    Jul 2016
    Quote Originally Posted by SHAWN DAVIS View Post
    Shawn , you on gas or alky ?
    Jan 2012
    Alky, lotta boost also
    I'm sure you would be fine with a standard injector and alky, I hold 24 gallons
    Quote Originally Posted by Gopher711x View Post
    Glad it's going good for ya. Looks like you're roughly right there at the 1000hp mark. I'll bet it does hammer hard!
    I love the idea of Methanol. For that matter, E85 too. However, for the type of boating I like to do (100+ miles a day), the optimum set up would be a table switching EFI deal that runs primarily on pump gas and automatically tapers into full Meth/E85 as boost increases.
    Second to that option, a simple water/Methanol injection deal on top of pump gas in either carbureted or EFI application. I don't see why more guys don't use this option, even NA engines. Especially in packages that are race gas only that are also cruised. Set it to spray at whatever manifold pressure ya need and be able to gas up at nearly any gas dock or local station.
    I get it though. We don't all have the same goals and there's certainly more than enough ways to get the job done. I don't think I'll ever be interested in learning to tune MFI... But one can never tell what the future holds. For the time being, I'll live that experience through you, if you choose that route. Do keep us posted.
    Senior Member Heatseeker's Avatar
    San Joaquin County, CA
    I always read the e85 threads with interest. I am on the fence with converting from pump gas. My dilemma is my boating style. I like to take long cruises on the delta with friends and hit the lakes now and then. I worry that the e85 load won't get me far enough, with nowhere on the water to refuel. I would love to put a little more boost to my set up though!
    Gopher, when you say you're burning through 10 gallons in 4 miles, where is your foot? Is that WFO or just cruising?
    Jul 2016
    Heatseeker, that's cruising at about 3k across the lake with an occasional quick stab for a second or two ...not really laying into it a lot ...but motor is no slouch....very healthy 555 with 2-1050 Dominators with full e85 conversions ..not just the do it yourself quick kits ...bodies and passages have been milled out w / .164 needles and seats , 4-#8 fuel lines supply bowls
    on gas I could make a lap around the lake hotspots on one tank , now it takes one tank to get to cove where everyone hangs out , one tank to get back
