No air filter
Results 1 to 8 of 8
No air filter
    Anaheim Hills
    Default No air filter
    I know it's rather common, to see hot rods on the river without a flame arrrestor or air filter on top of the carb(s). I change my oil nearly every time out, but I still worry about dead bugs and other debris being inhaled by the engine and hurting it. I see a lot of dead bugs on the intake scoop, especially in the evening; It's only obvious that some make it down the intake. I am considering running a flame arrestor with all but one screen removed (for better flow).
    Opinions and thought?
    This is the style scoop I'm running.
    Tower Park Resort, Lodi, CA
    Personally, it's the abrasive materials I like to keep out. Bugs don't bother me a bit, as far as the engine is concerned. However, I do suppose it's possible to have one clog an airbleed in a carb or something like that. My opinion anyway. I use a filter when I can, to keep the dirt out.
    Quote Originally Posted by NiceGuyEddie View Post
    why would you do that ?
    A K&N air filter will be fine or something from AIRAID: 800-307RD - AIRAID , Racing Air Filter
    Sep 2009
    Walled Lake, Michigan
    Default air filter
    I believe k & n makes one for bracket dragster applications. I believe Steve Williams developed it and represents them at the track while using them on his own cars.
    I searched something like "K & N dragster filter" and eventually found this link.
    http://www.dragraceresults.com/article.cfm?id=4101
    I do not know this company and have never used them. I just pasted it as an example.
    Darin
    Margaret Thatcher once said The trouble with socialism is that eventually you run out of other people's money.
    Sep 2009
    Default air filter
    I believe Steve Williams developed one at K & N. He uses them himself on his own dragster. I think it's a good idea to keep stuff out too. As mentioned the abrasive stuff in the air and bugs too.
    Darin
    Senior Member bp298's Avatar
    LHC
    been running these for almost 20 years. actually, I replaced with new one's sometime after this pic was taken. they slip fit over the barbon's. we ran with/without them on the dyno - couldn't even tell if there was a drop in hp. I won't run without them - too many tracks where you're in dirt/dust all weekend long, and it's in the air.
    Castro Valley, Ca.
    MY HP500EFI came stock with a K&N air filter, the engine is in an enclosed compartment, and in that environment the amount of dirt still being trapped is substantial. I would never operate an IC engine without a filter on the air intake system.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    waterloo
    BP... no wonder your shit is so slow!
    Wags
