Header primary size ????????
Results 1 to 9 of 9
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    Default Header primary size ????????
    Bassett offers a 2 1/2'' and the common 2 1/4'' when do you step up ??? If the motor is n/a and not blown is there any gains with the bigger primary ???? has anybody tested this on a dyno ??
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    i would say 2 1/4 with a n/a motor, because i think a little back pressure would be good.
    It's not that i don't care, I just dont give a sh!t!
    Boats N Hoes Brad22CP's Avatar
    Northern Cali
    What cubic inch?
    The Earth
    Blog Entries
    24
    2 1/4 will yield more HP on most any N/A engine unless it's a prostock or something very radical. 1 7/8" or 2" actually works better on most but they don't offer them any more since water injection came about.
    Quote Originally Posted by vee-driven View Post
    Pat, your probably right. I was hoping maybe somebody has tested it before I buy another set of 2 1/4'' .
    Quote Originally Posted by Brad22CP View Post
    What cubic inch?
    Its a 533ci. n/a jet boat.
    Rex, have you actually tested this ??? Does more exhaust "scavaging" take place with the smaller pipe ? Just figured if there is gains to be made, the price difference is not much.
    The Earth
    Blog Entries
    24
    Quote Originally Posted by 76Miller View Post
    I have not personally but have spoken with many who have over the years. 2" is generally considered about optimum (dry). When you add water 2 1/4" seems to work good. Note that all engines are different. If you have huge cam and heads you may need something larger. 2 1/2" on most N/A engines though would be considered too big. Only the dyno knows for sure on this though.
    Claremont, CA
    On a 409 1 7/8" seems optimum...2" looses power until over 6K rpm.
