540bbc
Results 1 to 5 of 5
540bbc
    Senior Member ps 14's Avatar
    Peoria AZ
    Default 540bbc
    My buddy just bought a 540 BBC project
    It came with AFR 345 heads roller cam 251/261 660lift 114 lobe center
    1071 blower and 1050 carbs complete package minus oil pan
    all new never been put together previous owner says it's a 1000 hp
    deal
    What are your thought on this combo it will be in a south wind tunnel with a stainless A impeller
    Peoria, AZ
    Quote Originally Posted by ps 14 View Post
    deal
    not really a blower guy, but depending on the overdrive and the fuel used I don't see why it could not get to that number. Any specifics in regards to Compression and if it has a chiller?
    Paul
    Peoria AZ
    Default Info
    No chiller came with 2 sets of pulleys don't have size of them Will get some more info tonight on it
    deal
    The pulleys and resulting boost will determine horsepower (and fuel requirements). I put together one that was set up to be a reliable pump gas engine, low boost through an intercooler, made 900 hp on a very well known dyno.
    As it happens, that engine is in a Southwind tunnel, with a pump set up by B1. I want to say the impeller is cut down a bit, but would need to check, the engine was my department.
    Mar 2010
    Clarksville, TN
    deal
    Should be a nice setup
