Question on carb wistle sounds
Results 1 to 7 of 7
    Senior Member cave's Avatar
    Mesa, AZ
    Default Question on carb wistle sounds
    This just started happening as far as i can hear I noticed it this weekend. As i was idling around the carbs or carb has a wistle sound. I had a few leaks in the base between the carb plate and the blower but tightened them up last week. Carbs are tight to the carb base. All the plugs on the carbs are new as are the rubber ones.
    I also plugged a nipple on my blower manifold that was to the regulators boost feature. Its blocked off now. I had a leak there before.
    the boat runs much more quieter now.
    Are there a better carb base to blower gasket? I got all these from Good Vibrations. They look to be good. But if there are better choices out there. Im all ears. The carb to base gaskets are all Holley.
    Takin it home
    460 is offline
    ATTA BOY 460's Avatar
    Jimmy,
    My boat does it all the time. Only started when i went to the dommi. Cant find out where its comming from
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Carb gasket.
    460 is offline
    Carb gasket.
    Funny you should say that. Jimmy was just hear and after us talking a bit i dont have a gasket and one of his is split. So he just left with 2 new gaskets and im going to make one to fit the domminator
    Mesa, AZ
    Quote Originally Posted by Fo Sitty View Post
    Jimmy,
    Carb gasket.
    Man I hope its that easy. I did see a gap in the gasket. Didnt hit me till you mentioned it Tyro.
    Thanks for the help guys
    Takin it home
    Both my blower motors do it after they are warmed up. But only on the down surge (if that makes sense).
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Cave,
    Next time it's running spray WD-40 or carb cleaner on the base of the carb or manifold to find the leak. If there's a leak you'll find it.
    S CP
