connecting rod comparison for a bbc strocker
Results 1 to 3 of 3
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    Default connecting rod comparison for a bbc strocker
    If you are looking at the same brand rods and one is clearance for a stroker application and the other is not. Where is the difference in the rod? Hope I asked this right. Thanks Troy
    Peoria, AZ
    Quote Originally Posted by APOLLO View Post
    It usually has to do with the clearance on the big end where the rod bolt is on a factory rod, or where the rod bolt comes through on a rod with a cap screw.
    I am sure others will have better explanations and maybe even pictures. I don't think there will be any sacrifice in strength.
    Paul
    MAHTOMEDI,MN
    Paul
    That was my thinking as well but was not 100%. My block is notched out so much to clear the rod bolt just like you sated. Kind of hard to see when there not next to one another. Thanks Troy
