looking for some input
Results 1 to 14 of 17
    SoCal
    Default looking for some input
    and who better to ask than you all.
    I have a 468bbc 800cfm carb on top of a dart single plane intake. oval port heads (stock and very tired), 9.5:1 flat top pistons, clay smith solid lift flat tappet cam (can't remember all the specs) 630 lift (i think), 4 bolt main, and
    new gm hp steel crank. It made just over 500hp with a bad distributor at 5800rpm.
    I'm looking to put a weiand tunnel ram, and rectangle port heads. I'm doing this on a tight budget and would like your input on a good set of affordable heads and what size carbs?
    This is in a flatbottom v-drive, casale 12* with 15% gears. prop is i believe a 11 3/4 x 13 1/4. not too sure, just had it tuned at hill props and not sure what it came out to. Runs good, 90mph (gps) at 6100rpm.
    Thanks for the input/advise
    You don't say whether alum. or iron. Do you already have the T ram and that is why your asking about rectangle heads?
    Canfield 310's and an Edelbrock Victor Ram, but youlre going to need a better cam for the combination if you really want it to work. Rect port heads are big for a small engine/low cr like that unless youre going to turn some r's.
    If you're interested, I have a nice set of big ovals with 2.19/1.88 valve that flow over 300cfm, and would make over 600 hp easy with the right set up. $1195 for the set, complete, fresh with all new quality parts.
    I would run ported 990s with the same cam! and a pair of 750s and you will be around 600 hp. I might even go 850s Thats a good combo cheap!IMO
    Quote Originally Posted by BASS LAKE BARRON SPRINT View Post
    This is why I asked if you already had the T ram. A good set of ovals and another 800 carb to match the one you have would be a decent set up. And get yourself a decent ignition!
    Senior Member Hullshot's Avatar
    Dicovery Bay
    Also double check your prop pitch and tach, either you are spinning alot more than 6100 or you have a lot bigger prop than you think or different gears than you think. #'s dont add up? right now you are over 100% effiecent?
    SoCal
    I know the tach and gear #'s are right, guessing on the prop.
    I do have the tunnel ram already.
    Steel or aluminum heads, does'nt much matter at this point.
    I'm happy with the current top speed, would like a better hole shot. I was also looking at some 12% gears.
    Thanks, keep the ideas coming...you guys
    Plus TR's just look cool! With your CR, iron heads, and 1 new carb and your set, with min cash outlay.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    SoCal
    So what are 990 heads? Anyone here selling a set?
    How much compression bump can I get from a smaller cc head? I think mine are 114cc now.
    2 800cfm carbs sounds a little/alot too much for a 468. Should I be looking at something in the 600cfm range with vac secondaries?
    Like I said before, I'm not looking to set any speed records. Just want a very cool looking river runner that is fast enough to turn the passenger white as a ghost
    Oh, I have a MSD billet distr. and MSD box. I think that should be hot enough for what I'm doing.
    990's are stock GM iron rectangle port heads. You would probably better off with something like this. There are manuf by Dart. If you are going to run it hard, change the exhaust valves out to at least Manley severes or better. It will be just fine with 2 800's, 750's were a very popular T ram carb for yrs. for a setup like yours.
    http://store.summitracing.com/partde...5&autoview=sku
    Nicely said gn7 !!!
    SoCal
    What about a compression bump?9.5:1 to 10:1. Can I get this increase with heads alone?
    Should the carbs be mech or vac secondary's?
    Assuming you have the piston .010 in the hole with a 18 cc (commom) dome and a 118 chamber, C/R now is about 9.58, a 114cc head will give you 9.89, and a 110cc head will yield 10.2. The Edelbrock oval head has a 110cc chamber, but won't clear alot of pistons. They will clear later SRP's. Depends on what you have in there. The Eddy's have small rectanglar shaped intake port that is smaller than your T ram. What manifold do you have now, single plane or 2 plane? As for the carb, if you are trying to stay in budget, match the carb you have now.
    Dicovery Bay
    990 heads with alot of port work, new springs and manley severe duty swirl polished valves.
ID:	38551   Click image for larger version.
ID:	38552   Click image for larger version.
