Bbc oil pan choices?
Results 1 to 8 of 8
    Aug 2016
    Default Bbc oil pan choices?
    Im in the process of building my first boat, its a 1970 hallett 18' vdrive. Im building a 427bbc, my questions is do i have to use a vdrive oil pan or can I get away with something else? because i dont have 600 to spend on a pan. Can anyone help me out?
    Quote Originally Posted by Brad Watkins View Post
    If you can't afford $600 for a V drive pan, either search for a good used one (probably in the $250 range or so), or wait until you can afford the proper pan.
    Do not try to "get away" with something that is not right, it likely will cost you a bunch more money in broken engine parts.
    Aug 2016
    Thanks i appreciate it
    Senior Member Johnny2bad's Avatar
    Sep 2009
    Land of 10,000 lakes
    Give Kevko a call.
    Tell them what you have and what you want.
    Family owned with a good product that won't bust the budget.
    Johnny
    Posted from my Etch A Sketch
    waterloo
    Tons of used ones out there. You don't need a 600 pan... You may want one... but you don't need it.
    Wags
    waterloo
    Is "Armando" still in business? He makes a nice, cheap pan... Very good piece. I have one. It ain't 600 bucks... but it keeps the oil in my BA 8.0 PE piece. It has a few hundred passes on it, no rebuild yet... so must have oil in it somewhere.
    Wags
    Castro Valley, Ca.
    My Armando pan is the first fabricated pan I owned that was absolutely leak free from day one.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    I just spoke with Armondo on Friday about building a V-Drive pan. I have to do some measuring first before I can order it.
    As far as pans go I ran my first boat (66 Stevens) for years with a stock pan. I had no clue what a V-Drive pan even was. I never ever had a problem. Turned a 396 6k rpm,s every weekend. I wouldn't do it now because I know better but It worked just fine.
