Vacuum leaks
Results 1 to 6 of 6
Vacuum leaks
    Rancho Cordova. CA
    Default Vacuum leaks
    I was on a Chevy truck website and a guy on there said he uses starting fluid to find vacuum leaks. I know this is a very bad way to do this. What is the best and safest way to hunt a leak? Thanks for any input!
    Quote Originally Posted by carreradude View Post
    Yes, not the safest way. As we know an engine at an idle will pulse ( at a low idle) at that point you can spray with very soapy water, watch the stream and it will vanish and blow bubbles in a cycle. This all depends on where you are looking for a leak and idle RPM. If you are chasing a leak at higher RPM you can use water and listen for a stumble just be careful not to use to much. M
    I haven't heard of using starting fluid, but I've heard of and used WD-40.
    The motor will speed up when the WD-40 is sucked in at the leak location.
    Starting fluid might damage paint on the engine, I'm not sure.
    It might work.
    Senior Member shan's Avatar
    Yuma
    I've always used carb cleaner.
    Quote Originally Posted by Spike Morelli View Post
    Golfers and Fishermen are third rate bullshitters, compared to lots of hot boaters....
    Whitewright, TX
    [QUOTE=jimsplace;4296178]I haven't heard of using starting fluid, but I've heard of and used WD-40.
    It might work.[/QUOTE
    EXACTLY! Used WD-40 many times back in the old days (High School) when I had junkier stuff or just probably didn't put shit together right, lol! Jocko
    Apr 2010
    Rocklin, Calif.
    Using starter fluid, will tell you if you have bad wires...BOOM
