Plug recommendation
Results 1 to 3 of 3
Plug recommendation
    Colfax, Ca
    Default Plug recommendation
    BBC 468, 12.7-1, Pro Comp 3021 heads, approx. 650+hp. Street use, a NGK R5671A-7 or equivalent is recommended. Thinking I need a little colder. Any suggestions
    Is this real or the "Twilight Zone"?
    Try an 8 if you want, but normal street range is hotter than 7, and a 7 is probably be what I would start with, then check the ground strap. You don't state your intended usage.
    Colfax, Ca
    It is the Bitch, now just a lake boat. Tired of trying to be the fastest.
