Blower surge
Results 1 to 14 of 26
Blower surge
    WHERE I AM IDAHO 392 cruiser's Avatar
    Default Blower surge
    TRYING TO STOP MY BLOWER SURGE , 392 HEMI ,871 MOONEYHAM STRIPPED ON GAS 278/282 DUR. INTERCOOLER,ZOOMIES ,CROWER HAT INJ, VERTEX, PORTED HEADS BLA BLA BLA OK DONT TELL ME ITS A RICH/ LEAN THING I KNOW ,,,, HOW DO YOU STOP IT , THIS IS A NEW ENGINE I HAVE NEVER HAD THIS HAPPEN BEFOR COULD THE CAM BE TOO FAR ADVANCED?? WHAT TUNING TRICKS SHOULD I TRY I HAVE A 3 LB IDLE SPRING 125 RETURN JET ENDERLE 80 PUMP. 32 JETS, DOUBLE AIR BLEED NOZZLES BUTTERFLIES A 10 THOU ITS A CROWER 4 BUTTERLY HAT WITH ENDERLE BIRD EVERYTHING ,,,,RUNNING 28 FIXED TIMING , 112 RACE GAS
    2008 KURTIS BLOWN INJECTED HEMI
    69' WICKENS
    try locking the timing at 26 if it gets worse try it at 30. retard is fat and advance is lean. My thoughts. M
    Kent, WA
    What is the idle check pressure set at ? 2,3,4 lbs ?
    Set it at 8-9 lbs
    Then adjust the barrel valve just to the lean side, right when it stops "hunting" !
    When you adjust the link, go a flat at a time, let it sit a couple seconds to clean out,
    if it needs a few more, give it more, just let it clean out at each flat.
    waterloo
    Fat idle makes it surge. WB hit the nail on the head. Lean it until it stops...
    But, do not lean to far!
    It will be slightly harder to start without a primer system or bottle....
    spring is 3 lbs now ill try to shim it tighter I don't have a selection of springs,, my hilborn 8 stack I never had a problem like this ,, this setup with gas im not going further than 28 on fixed timing even with the intercooler at 15 lbs boost its good. i just bought a inline an6 gage adapter and gage to see what idle pressure is at the barrel valve, ill crank it over tomorrow .I cant tell if the newer tight super charger or the cam change along with a different hat is compounding a small issue I did too many changes at one time now im lost runs great above 3000rpm
    69' WICKENS
    gage
    69' WICKENS
    Set it at 8-9 lbs
    it had a 3 lb spring guage showed 10lbs so ok I put a 8 lb spring in but gauge was pegged at 15 running 1800 rpm changed jets to 32 still seems rich I have a set of 30.s too ill try next also im going to drop the main pill from 125 to 130 ran a lot better but its a fine line on the rich to lean still. I do know now its closer when I kill the fuel to the engine its just flat stops before it would rev up 1000 rpm clean out , like leaning out, then stop
    , reving it up it sounds good no studder or popping didn't get a chance to lake test it but it still is drinking alot gas too.. blower pressure guage is still showing a hard 18lbs boost running even on the 871 with a 50 top and 50 bottom should I drop maybe to a 45 on the bottom since I have one that was going to be my top pully but that's a little too much pipoes are still suety black along with plugs but not putting anything down hard either
    69' WICKENS
    waterloo
    Not being disrespectful.
    It seems as if you are trying to solve a half a dozen different issues at a time.
    This never has worked well for me.
    You gauge looks to be on the inlet line. This will NOT reflect idle check valve setting properly. Bernoullis theorem??
    I learned how to set check valves from the Speed Sports fuel boat guys. Maybe they are right. Amos Saterlee seem to be somewhat knowledgeable (haha)
    They use "cracking pressure" to set the check valves. Use a good quality gauge from grainger. You only need a 50 psi gauge. Large diameter, as numbers are spaced farther apart. I have a 25 psi for idle, and port lines. A higher for high speed.
    Take the check valve out of the barrel valve. Use a leakdown style tester with the real gage. Open regulator until air begins to flow. This will be your pressure. I will look and seeif my setup is easily found, or buried in race stuff.
    So, I would go back to a basic tuneup. Enderle is the man. Goodvibrations motorsports will also set you up. Go from there. They will set you up rich. Of course... But it confirms all of your other settings are correct.
    Then, tune your top end.
    Then fine tune idle for your preference.
    I am sure you are well aware, mid throttle is not the MFI forte'.
    waterloo
    COME ON!!!! WHERE IS BOB?
    No one???? Anyone want to disagree?
    Remember the disagreements?
    The name calling?
    The flat, out pissed off?
    I know there were times, we all would have come to blows.. if sitting in a bar.
    All of us.
    God bless you Bob. We miss you.
    Wags
    Kent, WA
    I'll disagree with you on this, when it is set up correctly or "fixed" ,,, it can be a pleasure to use,,imo !
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    Can't wait to start asking these types of questions, resurrecting the BA engine.
    Anyone can pedal a bicycle, can you pedal a flat?????
    waterloo
    You can disagree... but it takes a tuner to get it set up. The average "joe" will chase his tail all day long.
    And, there are surely better systems for part throttle....
    Anything is possible, though.
    Wags
    Kent, WA
    I agree !
    Wags
    THANK YOU FOR ALL YOUR HELP/INSIGHT/KNOWLEDGE/ADVICE " MR. WIZBANG" YES IM GETTING CLOSER DOWN TO .030 NOZZEL JETS WENT BACK TO THE 125 MAIN TALKED TO MIKE GOT A LITTLE MORE HELP ON THE WINDOW BUT HAVE NOT BEEN ABLE TO GET IT ON THE WATER THE WEATHER HAS BEEN SUCKING MAYBE TUESDAY/WEDNSDAY I MOVED THE GAUGE TO THE DISTRIBUTION BLOCK 5#, I ALSO TALKED TO ENDERLE THEY SAY IM THERE ,,,SURE,, I ALSO DROPPED THE BOTTOM PULLEY DOWN TO A 48 LEFT THE 50 ON TOP RUNNING IN THE DRIVE WAY ITS RUNNING CLEANER AT IDLE THE SURGE IS WAY DOWN SOUNDS CRISP PLUGS BLACK AS SH*T,, I DONT THINK ITS POSSIBLE TO IDLE BELOW 1800 RPM WITH THIS SETUP /ENGINE
    ALL I KNOW ITS WAY DIFFERENT THAN A HILBORN 8 STACK WE WILL TALK MORE ON MY IDEA ON THE OTHER BV LATER
    69' WICKENS
