Air/Fuel ratio numbers - what does your engine like?
Results 1 to 2 of 2
    Apr 2012
    Default Air/Fuel ratio numbers - what does your engine like?
    What A/F ratios are you guys seeing that work well for a Naturally Aspirated BBC?
    My engine seems to want a richer mixture on the ramp up to WOT, (about 3/4 throttle) then it actually does at WOT itself. Is that normal?
    "I'd love to help you out wags, but there is larger issue concerning breast cup sizes on another thread that we have to work thru first. This subject suddenly became a non issue." - GN7
    Jul 2016
    Are you setting up your target A/F table ?
    I have been tuning on a Holley HP system on a friends boat.
    I could email you the target map but we are running E85.
    It's a shame this system doesn't do Lambda.
    There should be some preloaded tables in the files that came with the system that would be a reference for you.
