[Question] Connecting rods
Results 1 to 8 of 8
Connecting rods
    Apr 2011
    Spokane Wa.
    Default Connecting rods
    How much hp and rpm can a stock chevy big block rod handle? Thanks Jeff
    Quote Originally Posted by Hondo535 View Post
    That all depends on which stock rods you have?
    Apr 2011
    Spokane Wa.
    I'm not sure but I think they are 7/16. Does that sound right?
    Yes it does. If you look at the beams about 2 inches below the pin boss there should be a dimple on the rod. If there is, the factory 7/16 bolt rods are good for 650-700 h/p. I have pushed them further "after a good check-up" from a GOOD machine shop. I would replace the cap bolts after a clean bill of health from the shop. I have ran them on blown applications with no problems. Mark
    Apr 2011
    Spokane Wa.
    Thanks for the info. I plan on running the motor approximately 7200rpm.
    The dimple alone is not an indicator of a 7/16" rod, you need to measure the bolts. Various 3/8" bolt GM rods had "dimples"
    You don't mention engine specs or expected power, but why would you not run an H beam rod for that type RPM?
    Apr 2011
    Spokane Wa.
    I will try to get more info on the motor. It's a 468 that we are gonna use so I can finish the season. It's approximately 13 to 1 with a mild cam. We are gonna put some dart pro 1 super stock heads on it and maybe a little bigger cam. I'm not 100% sure it doesn't already have h beams in it.
