565 bbc h.p guess?
Page 1 of 13 1 2 3 4 11 ... LastLast
Results 1 to 14 of 172
565 bbc h.p guess?
    May 2014
    Default 565 bbc h.p guess? Dyno numbers finally!!
    Building a 565 bbc that should hit the dyno in a couple of weeks. 10.2 compression, bbxtra 3 heads cnc ported by rfd. Edelbrock tunnel ram with a pair of 1050 dominators. Custom solid roller from Straub around .780 lift. Hoping to make 900. What do you guys think?
    May 2014
    Heads flow 480 at .800.
    Member Tahoe540's Avatar
    Jul 2016
    Sparks, NV
    With those heads and cam you are on the right track in my opinion to make that.
    Mar 2010
    Clarksville, TN
    900 shouldn't be any problem, I built a similar 540 that made 900 with 2 750s
    May 2014
    I remember that motor. I pieced together all my parts and took them to my engine builder so if it doesn't make that it's on me. My builder thinks it will make mid 800's but I think it will be 910-925. I'm going to guess 914. Find out in a couple of weeks!
    with that compression I would think 750 at best? Please post up dyno results. See who wins?
    May 2014
    Man I sure hope your wrong.
    Quote Originally Posted by f-bomber View Post
    for your'e sake "so do I"
    Mar 2010
    Clarksville, TN
    I hope your just fucking with him
    Smile
    Just a pinch
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    Default Dyno
    Just had mine dyno'ed, BBC 540, 14.3 compression(advertised), AFR 345 heads(CNC chamber option), Isky 730 lift, 110 LC, 2- Carb Shop 1050's... made 842 HP @6600 RPM, 746 FT. LBS. TRQ. at 5100 RPM's.
    Anyone can pedal a bicycle, can you pedal a flat?????
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by fireboat607 View Post
    Really
    My 540 10.5:1 pump gas made 909 @ 6200 and 823 ft. lbs with 2 750s QF out of the box
    Good job Foxwell/Straub
    May 2014
    Really
    I wasn't going to say anything but 14.3 should make a thousand easy.
    Not all dyno's are created equal.
