Altenator wiring question (HEI SWAP)
    Jul 2016
    Default Altenator wiring question (HEI SWAP)
    I have a quick question.... I just swapped to a Hei and there is a wire coming from my altenator (yellow) that went to my 12volt side of ballast... Now that I ditched the ballast and coil, what do I do with the wire? Also what does the wire do?
    Im running a old school original Motorola marine Altenator that has the small yellow wire, and larger gauge orange wire going to battery terminal on fusebox.......
    Default Yellow Wire
    Quote Originally Posted by Farnorcaljetter View Post
    I think that the wire you are referring to is probably the "exciter" wire for the alternator. You state that it was connected to the B+ side of the ballast resistor. That would tell me that it would supply B+ to the alternator with the ignition in the "on" position. Just connect the wire to a ignition "key on" source. hope that helps. In some cases, you may need to install a diode in the exciter wire to the alternator, if it causes a "feedback" when the engine is shut down. (I would not connect the yellow wire to the HEI battery feed)
    Senior Member cakeeater ed's Avatar
    huntington beach ca.
    I know he answered your question, but this is just handy to have.
    Jun 2011
    Quote Originally Posted by cakeeater ed View Post
    X2....
