502 engine has partially melted piston
Results 1 to 6 of 6
    Aug 2017
    Default 502 engine has partially melted piston
    I just rebuilt one of my 502 Mercruiser engines and after 4 hours of use the #4 piston partially melted. Not sure what caused this and welcome suggestions. The builder installed new aluminium pistons and stainless valves. We have sent the injectors away for inspection and they came back good. All the valves and pistons look clean (even the melted one)like there was no detonation issues. Rings in good shape also. Any ideas what caused this??
    waterloo
    Heat?
    Olympia, Washington
    Lol, Waspe. If it is not pre ignition then it has to be lean on that cylinder for some reason.
    Castro Valley, Ca.
    I bought an Edelbrock manifold years ago that had the carb stud holes drilled all the way into the ports. Never noticed the defect during assembly, leaned that port and burned that piston. American made Edelbrock said not their fault, told me to pound sand.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Kent, WA
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    You will find the injector for that cylinder not flowing worth a crap.
    QE 439 Twin Turbo
