Cashaft identification help
Results 1 to 3 of 3
    Las Vegas, Nv
    Default Camshaft identification help
    I am trying to identify a hydraulic roller camshaft.
    The only numbers I can find are on the rear end bearing face.
    3319/329HR-9 HR112.
    The forward slash could possibly be a 1?
    Any ideas or help would be appreciated.
    Feb 2009
    SF Bay Area
    Maybe a Comp Cams hydraulic roller cam, 3319 lobe family on a 112 LSA. Call or e-mail their tech dept.
    If i were you I would send to a cam grinder if you don't have the tools to do it yourself. I have a grinder here in chino ca that grinds ALL my cams and identifies any cam I have a ? about. Guy is the cam GURU!!!!!!Mark
