Camshaft Question
Results 1 to 6 of 6
Camshaft Question
    Old Timer LeE ss13's Avatar
    San Dimas CA
    Default Camshaft Question
    APBA created a new Flatbottom Circle Boat class to accommodate non-capsule boats. It is called Super Comp. You have two motor choices. Option I is a $7,500 LS3 CT525 Circle Track crate motor. Option II, take your Super Stock 427 BBC and use a 650 Holley 0-80541-1 and a cam with no more that .550 lift and a duration of 230 @ .050 or less. Is there any advantage to changing the lobe centers? 112, 114? Also, is 110 octane fuel going to be good enough with 12 1/2+ compression? Is moving the cam timing any help? Total ignition timing change? Wadayathink?
    I don't know what I don't know because I forgot !!!
    Quote Originally Posted by Freedom Child View Post
    They all look alike upside down
    Quote Originally Posted by Wannabe View Post
    A grace of the English language that you obtain simply supersedes all reasonable expectations.
    Quote Originally Posted by LeE ss13 View Post
    With the tiny carb and short duration cam, maybe it just makes sense to use the crate engine, but can't say that without seeing specs on that engine. I don't think you gain power on that short cam by opening lobe centers, I think most circle track stuff will be tighter than that. I think the 110 octane is fine for that compression range.
    San Dimas CA
    LS3 Specs
    Part Number: 19331563
    Engine Type: LS-Series Gen-IV Small-Block V-8
    Displacement (cu. in.): 376 (6.2L)
    Bore x Stroke (in.): 4.065 x 3.62 (103.25 x 92mm)
    Block (P/N 12623967): Cast-aluminum with six-bolt, cross-bolted main caps
    Crankshaft (P/N 12597569): Nodular iron
    Connecting Rods (P/N 12607475): Powdered metal
    Pistons (P/N 19207287): Hypereutectic aluminum
    Camshaft Type (P/N 88958770): Hydraulic roller
    Valve Lift (in.): .525 intake / .525 exhaust
    Camshaft Duration (@.050 in.): 226° intake / 236° exhaust
    Cylinder Heads (P/N 12629063): LS3 rectangle port; aluminum “as-cast” with 68-cc chambers
    Valve Size (in.): 2.165 intake / 1.590 exhaust
    Compression Ratio: 10.7:1
    Rocker Arms (P/N 12569167 int): Investment-cast, roller trunnion
    Rocker Arms (P/N 10214664 exh): Investment-cast, roller trunnion
    Rocker Arm Ratio: 1.7:1
    Recommended Fuel: 92 octane
    Maximum Recommended rpm: 6700
    Reluctor Wheel: 58X
    Balanced: Internal
    Hmm,, iron crank, powdered metal rods, hypereutectic pistons,, $7500
    San Dimas CA
    Circle Track engine builders said that when Nascar shoved the LS motor onto their classes, the LS motors got to use an 830 cfm carb to their 390s. The LS guys tried to spin them 7500 plus and found them kicking out connecting rods. In the APBA version, they will be able to use a 750 cfm carb.
    Tri-Cities, TN
    A lot can be done with the BBC combination based on the rules.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
