Carb Jetting Starting point ?
Results 1 to 5 of 5
    Member Gopher711x's Avatar
    Jul 2016
    In a van...... down by the river
    Default Carb Jetting Starting point ?
    Dominator 1050s on a very healthy 8/71 blown 555
    Traded my e85 carbs , going back to gasoline .....
    lost all my old data I had written down on old tune up , but that engine was 454ci and not near what this engine is
    IIRC those jets were 89 squared
    anyone out there on gas running something similar in a 555 / 565 ?...where are you jetted ?
    It's me Gopher711 that's been on here for many years till the site got hacked , just added the "X" behind my old name
    Quote Originally Posted by Gopher711x View Post
    are you saying a 4500 series or a 4150 series 1050 on gas?Also with or without power valves?
    Put the carbs back to stock and start from there. If you want them done right, send them to AED.
    Jul 2016
    4500 / 1050cfm 2circuit. Gasoline , No Power valves
    Factory jets with no power valves for gas is 95 squared. the factory jets on a 4150 series 1050 with primary power valve is 90 98 on E85. You probably were very lean with your'e previous set up! Now with that being said they make different 4500 series 1050cfm carburators the only real deciding factor is the list number on the carburator. Mark
