Blown Injected Alcohol BBC
Results 1 to 14 of 30
    Senior Member fireboat607's Avatar
    Nampa, Idaho
    Default Blown Injected Alcohol BBC
    New years resolution ............................ build it!
    Anyone can pedal a bicycle, can you pedal a flat?????
    Peoria, AZ
    I approve of this message.
    Paul
    Member RivGuy83's Avatar
    Jan 2017
    Well is it done yet?
    Mar 2017
    this is one that you should keep.
    Peoria, AZ
    Quote Originally Posted by fireboat607 View Post
    I like the enthusiasm. So what is the build plan? What parts are you planning to use and what are your HP goals? Being winter we all could use a good conversation about boats and engines to keep us sane till spring.
    Paul
    Nampa, Idaho
    MK4 TD, bore 4.310, studded, 3.760 Callies crank, Arias #1130600, 12.1 - 1, Oliver billet(or aluminum) rods + .500, Isky cam RR-810-A - int lift .765, ex lift 748 W/ 1.7 rockers, dur at .050 - int 288, ex 296, lobe center 112( cam alittle large for this?, it's what i got) , World Products aluminum 360's or Grumpy Jenkins cast iron 350's, Indy TD manifold W/port injectors(if needed),Mallory mag III, 8-71 stripped Moonyham blower, Enderle bird hat. 8mm GT pullies, don't want to put it on kill, just something to tinker and learn with.
    Nampa, Idaho
    HP? .... I guess what ever the dyno spits out I'm good with.
    Peoria, AZ
    Sounds like a good combo. I was only asking to spur conversation. I did not know if you had parts, or starting from scratch and had a HP hope or expectation. Is this for a play boat or a drag boat? What hull is it going into? Just curious.
    Paul
    Peoria, AZ
    I loved hearing Oliver Billet rods - aluminum? Not so much.
    Nampa, Idaho
    Going in my drag boat, 1980 Hondo T-deck(in the picture), need to send out the injection parts to get flowed and find a good shop up here that will do an alcohol deal,( new to the area), don't know how may drag boats are in this area, closest track is in Oregon, that I know of.
    Kent, WA
    Imo, static comp is too high and it does need the ports !
    Senior Member capnfyr's Avatar
    Jun 2011
    Middleton, Idaho
    Default Blown Alcohol
    Call me sometime Fireboat. I live in the area and do have some local contacts. Wizbang can set you straight. Proven performance and durability in his motor combinations. He is a wealth of knowledge.
    Paul 208-409-7911
    Capnfyr
    1984 Daytona Sprint. AKA "Pyro Flyer" 2016 APBA High Points GPS 95 Champion.
    GN 8 AKA "Tinman" Under Construction. Back on the water for 2018.
    21' Eliminator Sport V Drive Lake Cruiser
    [SIGPIC]
    waterloo
    I've built a couple or so ish...
    You don't need to get it flowed..... especially if not on kill... get a generic setup from enderle.... port nozzles are a must.... and go for it.
    Wags
    My current piece has been tortured since 08... I would NOT recommend this... but it proves it can handle it... at least 2 years of smoking in the cove passes. I loaned it to a buddy and he went to infinity (sounded like it anyway) with it a time or two...
    I ain't no expert, though.
    Wags
    I'm just a boat bracket guy.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Compression is a bit much too learn with. Tune window is tiny. Unless it had EFI
    if you want the fuel system setup send it to Spike Gore.
    QE 439 Twin Turbo
