enderle 110 pump
Results 1 to 14 of 14
enderle 110 pump
    Senior Member creepingcharlie's Avatar
    Fresno CA
    Default enderle 110 pump
    Quick question? What does everyone use to seal the pump to cam drive extension?
    Quote Originally Posted by creepingcharlie View Post
    Thin layer of silicone. If some oozes out the side let it set for a day or two and you can roll it off with your fingers instead of smearing it while it's "wet"
    Peoria, AZ
    Bingo!
    waterloo
    Yup, everyone does it...
    I use ultra black with the black enderle extension.... no color mismatching allowed!
    Fresno CA
    Thanks guys. I figured it was silicone. But was not 100%. I am a little surprized that it is not a o ringed connection for easy removal and assembly for maintenance.
    waterloo
    If it is an enderle 3 piece extension.. you can buy a quick release adapter for the extension. A quick release adapter for the pump, and a QR clamp.... then you aren't breaking a seal a dozen times a year.... just EASIER
    Good vibrations racing has em... reasonably priced.
    Wags
    Kent, WA
    I use a RCD fuel pump driveshaft, and then machine a round bore inside and add a seal ???
    ( I'm a dumbass )
    waterloo
    ( I'm a dumbass )
    Hell yes, that would work. Most guys don't have access to lathe, mill, etc...
    AlkyDigger Alkymike's Avatar
    Jan 2018
    Post Enderle Fuel pumps
    Light smear of clear silicone - our extension is sealed by the front bearing , so it can't get into the engine anyway.
    Jan 2018
    Default Sealing a pump extension or pump to Timing cover
    Thin smear of silicone
    Fresno CA
    Wags
    Going to look into this. Thanks
    Fresno CA
    ( I'm a dumbass )
    Would this be able to be done with a enderle pump?
    Fresno CA
    Quote Originally Posted by Alkymike View Post
    I had a little bit of oil in between the pump and extension. I was thinking that it was there to keep the bearings lubed.
    Jan 2018
    Default Enderle Fuel Pumps
    No, the bearings are sealed. The oil just came up through the chain or gear drive.
    The bearing in our extensions are sealed s well.
    Just a dab of silicone will almost always fix that issue.
