Head gaskets
Results 1 to 5 of 5
Head gaskets
    Aug 2016
    Default Head gaskets
    Mark 4 block and 088 heads what head gasket do i need v-drive applacation not sure of bore till i check it
    Quote Originally Posted by 78howard View Post
    454 block rather than a 502 block? What type of compression, or will it have forced induction at all?
    Aug 2016
    454 block maybe 11 to 1 n/a with tunnel ram
    OK, rather than just telling you to use a 17040 Fel Pro marine head gasket, I looked it up. Doing it myself I have the gasket on the shelf and would check against the head and block, but here is the page that explains it. Make sure you have the necessary 3/16" margin across the top for proper sealing.
    Felpro Marine 2010
    You may also chose to run a 1071 MLS gasket, more expensive, and it's supposed to require a smoother finish on the block and head, I run them on forced induction engines.
    Default Head bolts/studs
    Give the gaskets a chance to seal by using NEW fasteners.... Bolts or studs, what ever you choose, but make them quality and new and follow instructions about torque and thread lube....
    Ray
    LOUD BOATS SAVE LIVES
