Well got started on the Whipple project - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 24 of 24
  1. #15
    New here Beer:30's Avatar
    Bakersfield, CA
    Quote Originally Posted by Ultra26 # 1 View Post
    ?? Reversion ??
    Intake ports should be bare metal-looking. No coating at all. You can see the black in each intake port. The only way that can get there is coming back into the intake from the chamber after a power cycle. The way this happens is restricted exhaust that causes backup in the flow. A little exhaust gets pushed backward through the system.
    The further along the tract it gets, the more restriction there is. Some are so bad that the bottom of the throttle blades of a carburetor are black.
    It can also come from a combo of exhaust and cam overlap. Overlap is not an issue with an HO cam, though.
    Ultra26 # 1
    Guest
    Thanks for the explanation. You must have much better eyes than I as I can't see inside the ports to determine their color. If we were dealing aluminum heads I would understand and agree.
    Again, thanks
    John M
    PS I also thought that the term 'reversion" generally referred to water ingestion
  4. #17
    Bakersfield, CA
    Reversion is simply "backflushing", if you will. Be it exhaust, water, or both.
    Senior Member KineticoH20's Avatar
    Chino Hills
    Status?
  7. #19
    Senior Member I DIG IT's Avatar
    spokane WA
    Well got more done this weekend. Getting really close. Got all the dash and gauges done and whipple said that my ecm should be here monday. I'm thinking that I should be able to fire this thing off this next week. Next weekend there should be some water testing. Then I still have to start on the rear hatch and seat mods. But I'm leaving all of this off till I'm happy with the install and tuneing of the motor. Here are some more pic along the way
ID:	3510   Click image for larger version.
ID:	3511   Click image for larger version.
ID:	3512   Click image for larger version.
ID:	3513   Click image for larger version.
  8. #20
    Ultra26 # 1
    Guest
    You're getting close and it's looking real nice. Boating in the high 40's? Me too if I just Whippled mine.
    John M
    PS What are you using to mount the new gauges?
  9. #21
    spokane WA
    There little pods with all thread that you drill a bunch of holes in your dash. Theres three all threads that go through the dash and you bolt through on the bottom side. Then you drill a big hole in the center for wires and hoses exc. In the pic I still have the tape on the dash to help prevent the gel from chipping. Let me tell you Is not fun trying to run all the shit inside and still get a backing plate on to hold the guage in. Not much room at all. I hade to use tweezers to get the nuts on. In the pic none or the gauges are mounted yet, just sitting there.
  10. #22
    spokane WA
    If you look to the right you can see the template I made to lay them out. When I got done they all fit and lined up strait!!! It's still scary drilling a ton of holes in the top of your dash, but I think they look good there.
  11. #23
    Ultra26 # 1
    Guest
    Quote Originally Posted by I DIG IT View Post
    The pods are very cool. First time Ive seen them. The pods look as if they are powdercoated to match your other gauge bezels.
    John M
  12. #24
    Distinguished Member 92562's Avatar
    Murrieta
    Thumbs up
    Looks like you are doing a great and thorough job Brayden! You should ditch work and test it at Havasu at the end of the month when I'll be there!
    ---Rob
