Help choosing a cam for a ZZ502
Results 1 to 9 of 9
    Junior Member ASantos's Avatar
    Jul 2010
    East SF Bay Area
    Default Help choosing a cam for a ZZ502
    Hi, can anyone recommend a cam for a ZZ502 that I'm putting in my heavy layup 18' Jet Boat(sorry in advance lol)?
    ZZ502 9.6:1
    GM Performance Aluminum Heads 290cc 110cc combustion chamber CNC'd.
    GM Performance CNC'd dual plane intake
    Holley 850DP
    Hardin Marine Logs/Snails
    Haven't decided on impeller, but will test a few different ones. Race prepped B to a AA, not sure yet.
    Hydraulic Roller preferred.
    Thanks, in advance.
    1990 Keaton 18J BBC
    Peoria, AZ
    Are you planning of using the factory roller lifters? Springs? What valves? What exhaust? These are all factors that would play into getting the right cam. In my opinion I would contact Chris Straub and have him grind a cam for your specific needs. Every cam I have got from him delivered results better than I would have expected based on my own experience picking cams. Also, he is a great resource for parts if you need them.
    Paul
    Quote Originally Posted by ASantos View Post
    ZZ502 9.6:1
    Holley 850DP
    Thanks, in advance.
    You also really need to decide on impeller (and RPM range) to select the right cam.
    Jul 2010
    East SF Bay Area
    2.25/1.88 SS valves, stock springs, die cast roller rockers 1.7, aftermarket roller lifters. Logs/Snails. Thanks for the help, I'll try Chris as well. Thanks,
    1990 Keaton 18J BBC
    Peoria, AZ
    Great point! Being that I am a v-drive guy I can gear to the RPM I want, but I forget that you jet guys have different limitations to fight.
    Paul
    Apr 2010
    Rocklin, Calif.
    Cool
    Barry has a GOOD cam grinder..send your cam for a regrind..Straub will cost you $575 for the cam..mine sucked big time
    Give Chris a call (Straub). He's done a bunch of 502's. His cam's don't suck and neither does his reputation.
    You need to figure on how much power you want to make and what RPM you want to make it.
    Jun 2011
    Quote Originally Posted by scott foxwell View Post
    Spoke with Chris on the phone about my set up.....Nice and informative and will be sending my stuff to them....with no doubts.....
    Tri-Cities, TN
    If your unhappy with a camshaft then please contact me. 423 391 7774.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
