New CNC BB Chev dedicated nitrous/pwr adder heads
Results 1 to 8 of 8
    Default New CNC BB Chev dedicated nitrous/pwr adder heads
    We have our final CNC version; AFR casting set up as nitrous head, 351cc (right port), 3.48 min cross section, 2.375 / 1.85 valve, 116 cc chamber, 50* valve job, alloy seats, steel ex guides w/ liners, 460 cfm int, 340cfm ex on 4.60 bore. This set is for Troy LaCrone's new all aluminum 582 ci BB Chev that will see Drag Week this year. We have several BB Chev CNC programs available.
    Flow numbers for these heads;
    ......Right / left / ex
    .2 152 / 152 / 128
    .3 230 / 230 / 200
    .4 303 / 303 / 254
    .5 352 / 358 / 291
    .6 405 / 387 / 316
    .7 434 / 413 / 329
    .8 445 / 432 / 334
    .9 451 / 443 / 340
    1.0 459 / 457 / 341
    If looks mean anything I'm sure they will perform very well, nice job.
    Member CycloneRacing's Avatar
    Jun 2017
    Long Beach
    Thumbs up
    Those look very nice Scott.
    Good work.
    May 2014
    Meadow Vista Ca. Huntington Beach Ca.
    I love this performance porn.
    I notice that the inside intake ports look slightly smaller. Is this to increase velocity ?
    Good looking heads Scott , what other bbc heads cnc porting can you do? Cost?
    Thanks,
    David
    Quote Originally Posted by speedtrap View Post
    Thanks,
    David
    Hey David, thanks. What you're seeing is just the pic...port cross sections are the same.
    We have several BB Chev programs, best to just give us a call if you're interested in some pricing. Straub Technologies...423 391 7774
    Mar 2010
    Clarksville, TN
    Makes me feel all warm and fuzzy inside
    Tri-Cities, TN
    Dyno Test of heads.
    Engine
    Pump gas 582 12 To1
    AED MAX Dominator
    Ported Sniper Intake by the Fox
    Scotts Power Adder 3.0 Grudge Program in a set of AFR castings
    Harlan Sharps New Shaft System for AFR Heads
    50MM Custom Straub Camshaft
    Morel .936" Keyway lifters
    CP Custom Piston
    Jager Aluminum 6.7 Rods
    Callies Magnum XL
    Brodix Aluminum 10.200
    Stef's Heads up Pan, Wet with Melling Pump
    7/16" x .165" Smith Pushrods.
    NA pull, 93 Pump gas 36 degrees
    Nitrous pull, IS Modified Sledgehammer Plate 500 Jet, Race Gas 20 degrees total
ID:	1024355   Click image for larger version.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Peoria, AZ
    I would be proud of that.
    Paul
