Enderle barrel valve
Results 1 to 6 of 6
    Apr 2013
    Default Enderle barrel valve
    Just wanted to know how it works. I just bought my first injection from them. Its a square barrel valve for a blown gas set up. Thanks.
    Peoria, AZ
    Who did you buy it from? If you bought it from Good Vibrations motorsports then call them and have Jim give you a run down of how everything works. He is a great wealth of knowledge. Even if you did not buy it there, there site has some tech videos and diagrams that should help. Also, another place for info is fuelinjectionent.com Spud Miller owns that shop and is pretty dang good at injection systems. Also, his site has some more good tech diagrams and info.
    Being that we don't know what all your system has we can't give you specifics as to setup. We don't know what spool the BV has or what bypasses you are running. Are you running just hat nozzles or hat and port? That all makes a difference.
    Paul
    Apr 2013
    Paul
    Brand new from Enderle, and they set it up as well. This is new to me, and I guess I'm trying to understand how fuel flows through it, and how the check valves start to work.
    Quote Originally Posted by 68sanger View Post
    Enderle is an old school type company that has been great about helping me the couple of times I needed things from them, including custom length linkage rods and a quick turnaround flowing a fuel pump for an engine that was on the dyno.
    I would not hesitate to call them and ask for help.
    Peoria, AZ
    If enderle set it up it is probably like this.
    https://www.alkydigger.net/TechInfo/...blown-alcohol/
    Here is another source for info. This write up is pretty decent and the diagrams at the bottom of the page are better than many on the internet.
    Blown Injection
    Both these sites have good info and tips. Read up.
    Paul
    Apr 2013
    Blown Injection
    Paul
    Thanks those were helpful. That's how mine is setup. One thing I didn't understand is why on a blown gas setup did they use a blank where the main bypass goes.
