Dan Olson Gen V bbc oil cooler installation
Results 1 to 5 of 5
    Las Vegas, Nv
    Default Dan Olson Gen V bbc oil cooler installation
    I have searched all over and cant find any information, on how to install a Dan Olson block mount oil cooler on a Gen V bbc.
    Does any one have any pictures, of how they are mounted, or installation instructions or can lead me in the direction of where to find installation information?
    It would be greatly appreciated.
    I have already looked on Dan Olson website and came up empty
    Senior Member Eliminator21vdrive's Avatar
    Jun 2011
    Diamond Springs, California, United States
    Generally you remove the filter adapter from engine block and bolt uo cooler with two o rings on top and l bracket on housing bolts to block.
    Have any pics?
    I see this is a couple of weeks old, but pretty sure they bolt up just like a Mk IV cooler, just made different due to the difference in the block.
    Other trick would be to phone Dan Olson.
    good call on talking to Dan. the gen v has a relief system that is different than the iv. Possibly the oil pressure will start acting up, as in high to low scenario. FWIW then gen 5 has a relief built into the block. Mark
    The Gen 5 and 6 blocks have two removable pressure relief valves, one to divert oil to the cooler which is not needed if you do not run those ports in the block, and the 2nd one I normally plug with an expansion plug.
Similar Threads
  1. Dan Olson Gen 5 block mount oil cooler installation
    By holorinhal in forum Jet Boats
    Last Post: 03-22-2019, 12:02 PM
  2. Dan Olson Oil Cooler and K&N Oil Filter
    By LeE ss13 in forum V-Drives
    Last Post: 09-10-2016, 07:37 PM
  3. [SOLD] BBC Dan Olson Oil cooler
    By jdl25_1998 in forum Parts for Sale
    Last Post: 09-07-2012, 03:04 PM
  4. Dan Olson Oil Cooler - BBC Gen V
    By willis in forum Parts for Sale
    Last Post: 06-27-2012, 04:43 PM
  5. Dan Olson Oil Cooler for BBC
    By K-33 in forum Parts for Sale
    Last Post: 10-28-2009, 05:32 PM
