[Question] Ex, rockers.
Results 1 to 14 of 21
Ex, rockers.
    Sep 2012
    Default Ex, rockers.
    Looking for advice, I have a new to me Gen V BBC tall deck, I pulled the girdle and rocker arms off to check everything out and noticed that exhaust rocker are hitting the poly locks at close to max lift, looks like the builder ground the slots the clearance them, any suggestions on what I need to do to correct this? Roller cam 825 lift, comp rocker arms.
    Quote Originally Posted by Bobbylisa View Post
    I would first check rocker arm geometry and make sure the pushrods are the correct length.
    I agree with the possible incorrect push rod length.
    When the rocker is in the extreme opposite position, is there still clearance for the Poly Lock? While there is a method to set up the geometry, it should normally have clearance at both extreme lift and at the other extreme too.
    Jan 2010
    So Cal
    ^^^ This^^^
    Use the mid-lift method to determine correct pushrod length.
    Sep 2012
    Yes there is clearance when the valve is closed.
    Senior Member capnfyr's Avatar
    Jun 2011
    Middleton, Idaho
    Default Tall deck.
    Go on you tube and look up the Straub engineering video on how to determine correct push rod length. This easy to follow and understand video is done by Scott Foxwell and goes through the process step by step. It's definitely helped me out when you get into or find these situations. Good Luck.
    Capnfyr
    1984 Daytona Sprint. AKA "Pyro Flyer" 2016 APBA High Points GPS 95 Champion.
    GN 8 AKA "Tinman" Under Construction. Back on the water for 2020.
    21' Eliminator Sport V Drive Lake Cruiser
    [SIGPIC]
    Hope this helps:
    Sep 2012
    Quote Originally Posted by scott foxwell View Post
    Hope this helps:
    Sep 2012
    Default Re-push rod.
    Looks to be a little off, studs are to short also rocker is on the threaded part of the stud.
    This is all very educated advice for proper valve train geometry. M
    Peoria, AZ
    Where are you located? Someone nearby might be able to help get this sorted out.
    Paul
    Sep 2012
    Default Re
    I think I have it figured out, went over it a couple of time and followed Scott’s video, a little surprised thing are this far off.
ID:	1033453   Click image for larger version.
ID:	1033455   Click image for larger version.
    I'm not. What you're liable to find now is that the rockers aren't right for the heads, and the sweep pattern will be way off to the exhaust side, especially on the intake valve.
    Sep 2012
    What would be a good rocker choice?
