[Pics] Morel Lifter Failure?
Results 1 to 14 of 20
    Jan 2010
    So Cal
    Default Morel Lifter Failure?
    I put this engine together in 2011, and have approx 450 hours on it. 516 BBC, AFR 305s, approx 9:1, Straub has roller cam.
    Down on power and sounded like it lost a cylinder. Tore it down and found 4 sets of tie bars broken off.. . One spun and took out #2 intake lobe.
    Obviously this didnt happen all at once, but more importantly, WHY did it happen? Any insight or ideas are welcome.. Im dumbfounded.
    Dave
    Jan 2010
    So Cal
    Quote Originally Posted by 28Eliminator View Post
    Dave
    another try at the Pics
    Those are street series lifters. They have been run way beyond their intended use. Any time you see tie bars breaking like that it's due to serious valve train issues. Springs have probably gone away and engine was continued to be run hard.
    Jan 2010
    So Cal
    Quote Originally Posted by scott foxwell View Post
    The street series have the .700 roller don't they? These had the .750 roller. Cam only had .650 lift. Springs replaced at 200hrs, and again at close to 400. 200Lbs seat @1.95. Rockers were set up at Midlift.. Custom pushrods made for it. This engine never saw 6k. I think I had it up to 5600 or 5700 a couple times. Is it possible these were some of the rumored "chinese knockoffs" that were allegedly floating around years ago?
    Peoria, AZ
    Holy crap! I have never seen anything like that before.
    Paul
    My bad...yes, those are the retro drop in's with the .750 wheel.
    Did you get the lifters from Chris? Is there a small black X on the tie bar anywhere?
    Need a close up of some of the lifters.
    Jan 2010
    So Cal
    No. I bought them from Teague. I bought most everything else from Chris. No black X anywhere..
    I guess all the questions have been answered on another thread (River Dave's).
    Definitely Morel.
    Bottom line is, when tie bars start braking, the valve train is VERY unhappy, for whatever reason.
    You have 200+ hours on this set of springs. That's the first place I would look.
    In 400+ hours, I would hesitate to say this engine has "never" been over 6000rpm. That's just not realistic.
    How many hours did it spend over 5000 rpm?
    Merc Marine recommends replacing lifters at 200 hrs.
    Tri-Cities, TN
    There is no load on tie bars. When a tie bar breaks the engine has harmonics in the valvetrain. From the pictures you posted on the other site, you the tips have the "star" pattern and your getting harmonics. The heads need to come off and be thoroughly checked. 450 hour is a ton of hours on a performance engine. Merc says to replace parts on the HP series stuff after 200 Hours. The lifter was getting the abuse and could not take it anymore in this case. Please let us know what you find out.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Steady Rollin
    Corona
    Definitely Morel.
    so for general purposes...
    check springs at 200 hrs, if they are in spec can they be reused? or should we just swap them?
    same goes for roller lifters? is 200 hrs a good checking point?
    I just had an engine built and wanted to get some good estimates on windows for inspections.
    The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants.
    -- Thomas Jefferson
    Quote Originally Posted by sintax View Post
    It's going to depend on the use or abuse. The 200hr mark seems to be what Merc Marine uses. If the springs are in spec, you can continue to use them but just be advised...everything, especially in the valve train, has a cycle life. Springs can go from "usable" do duds in a matter of a day's use without warning once they've reached their cycle life. That's where a really good quality super clean spring is worth it's $$. Needle roller lifters really don't have a "going bad" indicator. A bushing lifter will tell you when it's in failure mode. Lifters can be sent in for inspection and rebuild but it's time consuming. We tell most people that if their program is such that they thing they're going to need regular maintenance and rebuilds on lifters, have two sets. That way you'll always have a set to work with while the other set is being rebuilt. Of course, having the valve train up to the task including proper pushrod length and rocker geometry will go a long way to increasing service life.
    Hope that helps.
    Steady Rollin
    Corona
    Hope that helps.
    Yea it does Scott.
    thanks
    -- Thomas Jefferson
    Jan 2010
    So Cal
    Definitely Morel.
    Scott, please re-read post #4. Valve springs were replaced at 200hrs, AND AGAIN AT 400. These springs have around 50 hours on them.
    In addition, I wasnt kidding when I said this engine has never been past 6k. Why would I lie? Have you been in my boat when I ran it past 6k? Its a 28 Eagle.. a v hull boat with a bravo 1 drive. Once again, IT NEVER SAW 6k!!.
    First, I got 9 years and 450 hours out of this engine, and I was very happy with it. Im not trying to point any fingers, or blame anyone or anything. I simply want to know what factors could have contributed to this failure so I can make sure it doesnt happen again.
    I know you and Chris are big Morel cheerleaders.. I get that. I bought parts from both of you for this engine originally. The Lifters I bought from TEAGUE, not Chris.
    Valve float for as long as youre assuming would have damaged valves, marks on the pistons? Or even have marks on the backside of the cam lobes from the lifters bouncing.. No?? Bent pushrods? None of that exists. So understand my skepticism on the valve float/harmonics theory.
    I cant get past the tiny rivet cross section on the back of the tie bar buttons..
    If I were you I would contact contact Howards cams and run it all buy them. I am knocking any body on this response BUT sometimes another opinion never hurts. I agree with alot here " especially the chinese knock off part" They build their own parts and will give you the straight up opinion. They have been doing this stuff along ALONG time and alot of cam grinders recommend their stuff. Again no offense to anybody here but everybody can use another opinion from time to time. Sometimes its a learning experience for all..MLAOP. M
