Dyno tested fuel?
Results 1 to 6 of 6
Dyno tested fuel?
    Southwest corner AR
    Default Dyno tested fuel?
    Has anyone dynoed a mill using different fuel such as 93 octane compared to 111-112 octane? Lets say a 468 pump gas motor 10.1 comp. What were the differences in HP on race fuel?
    It's my understanding that when you use a fuel with a higher octaine than you need , you make no more power, and more than likely less, because the higher octaine burns slower.
    Southwest corner AR
    I have been told that before. But a 10.1 to a 10.5 -1 is pushing the envelope on pump gas and I was wondering if race fuel will make the same motor tested {dynoed} had more HP?
    Unless you use a fuel that's oxygen bearing, a better fuel itself won't make more power. What a better fuel does is allow you to use higher compression ratios, more timing, etc... which in turn makes more power. If your engine is not detonating on the fuel your using, there's no more power to be had by using higher octane levels.
    Southwest corner AR
    That is what I wanted to know! Thanks
    Ladera Ranch
    Lots of people running considerably more than that in boating applications with success on pump gas.
