oval to rect. port manifold - Page 3
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 29 to 42 of 66
  1. #29
    couldn't load the pic(gif format) but here's a link, its the top plate pic. i'm runnin the twin pro power gemini set-up which looks about the same but my plate is for dominator, 2stage. i like nx products my plate is at the bottom of the page(np957).
    http://www.nitrousexpress.com/Pages/NitrousPlates.htm
    cfm
    cfm is offline
    Does that middle section spray straight down or angled to both sides ?
    As far as NOS - many builders feel more comfortable using a single plane intake manifold with more than 125 shot.
    Remember - a dual plane physically splits everything in half.
  4. #31
    angled out. on my plate , even the outter part of the plate has holes in it for the 2nd stage. pretty cool looking.
    cfm
    cfm is offline
    Well, with a 150hp shot and possibility of going higher, I'd strongly consider going this way - it should be the new Team G:
    http://store.summitracing.com/partde...0&autoview=sku
  7. #33
    Senior Member hotbo's Avatar
    lake Ouachita AR
    okay so your saying shit can the rpm air gap all together
    why is the new team g better than an older one????
    if i do this and it will cost some dough should i get a rect. or oval???my heads are oval.
    what in reality could i expect?50rpm is that enough to mess with???for 200 plus and then gaskets???
    no one has anwsered my question the rpm say up to 6500.
  8. #34
    the new team g has a bigger plenum volume to keep up with higher rev'n bbc's with oval port heads. i never new they made 1 for oval at all, or is that new to them also?
    how far up into your scoop does the carb sit now or is it pan mounted? can't remember ever seeing under your cover.
  9. #35
    lake Ouachita AR
    no its mounted to the cover with the air cleaner i have maybe 2 inches left but i can do away with the air cleaner and run without it,dint want to but what ever it takes i can do no biggie.
    one of the motors we sold brian has a team g oval and its a older version i had it off.
  10. #36
    think cfm or steelcomp said those older 1's had small plenum volume didn't they?
    wat ya runnin a filter for? guarantee ya my blower motor ate it's weight in skeeters and dragonflies last summer
  11. #37
    lake Ouachita AR
    well tom to be honest just a something in case it backfires or hell ya never know i can do away with itits a one nice one tucks into the scoop and it has the flow thru top
    well crap im all screwed up.guess ill be buying a tall single.
    so the new team G will be the best rect,oval??
    how about dart,brodix,victor jr.they good to.the rpm range seems way up there on those intakes 4,000-8,000 seems way to high the team G says what 2,000 up??
    what to do
  12. #38
    cfm
    cfm is offline
    Performance wise, if you are already happy, then leave it alone.
    We are just giving you info on something that should be a little better. That's all.
    Again, with bigger shots of juice or with blow thru SC, most would rather have a single plane intake. A little more safety margin and usually a little more power. Enough for a few hundred rpm ? Doubtful, but then that's what bigger nitrous jets are for. LOL.
    The new Team G was designed with computers and supposedly wet flow benches. The old Team G was a decent intake for it's time, but with modern day machinery + modern killer cyl heads and cams, it was time. Thus the Air Gap RPM's and Air Strikes too.
  13. #39
    what to do
    dude, if ya can swing it, go for the oval team g cfm linked up, looks like a good intake for your combo bet you even pick up a few rpms.
  14. #40
    lake Ouachita AR
    well cfm are any of use really happy,lol!!!!i dont mind buying the team g the part that i do mind is putting it on and not seeing any gain at all that will piss me off,lol!!!!!!!!i guess what i will do is like tom has stated put the new G on and be good to go,you da man tom there i said it cry baby you happyim just trying to optimize what i have if it was in the books there would be a ton of things i would do,bigger mill to start off with.im game if it helps the nos out i didnt know that single plane intakes were the best for the juice.
  15. #41
    won't cost ya 100 bucks to try it man, throw the rpm onto ebay, make 1/2 you $$$ back ***** i know your ass has enough things layin around to sell to pay for the intake and gaskets.
  16. #42
    lake Ouachita AR
    you can stick it pal you buy it for me
    yeah i guess may as well
