blown 572
Results 1 to 8 of 8
blown 572
    Senior Member ovrkll77's Avatar
    CALI
    Default blown 572
    what do you guys think? I'm having a shop in w covina build me a blown 572. I am using dart 345 heads with a stage 3 porting (using these heads cuz I already had them). motor will have 8.5:1 comp. 14 71 blower with a 749 lift.
    Builder says I will make over 1100 hp. Is this possible with these heads?
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    Anything is possible with more boost!
    It's not that i don't care, I just dont give a sh!t!
    Member ezstriper's Avatar
    fredericksburg, va
    exactly !!!! should not be a problem, now fuel, that might be !!
    CALI
    I want to be able to run pump.
    Anybody have experience with speedomotive
    Senior Member Sanger Greg's Avatar
    SFV LOS ANGELES
    Default HP
    make sure you run a good intercooler, and keep your water temp low 120-140 then run an oil thermostat to stop condensation. I am running these # with 598" motors.
    I run the dart 345 none ported head on my pro limited motor , meaning one carb no porting 482 ci made 850 hp @ 7200 it can be done .
    CALI
    well motor is almost done. needs to go on the dyno, i think this shop is expensive as far as the dyno work. I know it's cheap insurance but ive heard of shops charging $400 for the dyno.
    CALI
    Quote Originally Posted by x50plt View Post
    I have 2 intercoolers, 1 has bigger end caps for more water flow. I will try both to see the differences.
    I never ran an oil thermostat, is it a big deal?
