502 HO 450hp
Results 1 to 10 of 10
502 HO 450hp
    Default 502 HO 450hp
    Has anybody taken apart a Gen VI 502 HO?
    I have heard they have SRP pistons, true or false?
    Ladera Ranch
    only one way to find out!
    Peoria, AZ
    The one I rebuilt had JE pistons in it. (At least that is what was cast on the bottom of the piston).
    Paul
    Je/srp
    It's good to be alive
    Lake Havasu
    JE and some pretty crappy machine work.
    Yeah I know, I just dont want to tear into the engine before I get
    the pump back in.
    cfm
    cfm is offline
    All 502's have 4 bolt main GM 502 block, GM steel crank, 7/16" rods, and special J/E pistons with non typical rings 2MM / 1.5MM / 4MM low tension oil ring.
    Great, should be fun to find rings for.
    I was told that a gen 6 502 is externally balanced by tech support at Scoggin Dickey today.
    that seems strange to me.
    cfm
    cfm is offline
    Actually pretty easy to find rings for it - just get ready to pony up. Call Scoggin Dickey back - they have the regular rings and also a file fit set with a regular tension oil ring. Your choice - the regular set has low tesnion oil ring that will just use some more oil.
    Yup, they are ext balanced. Not strange at all. All 454's are ext balanced too.
    Thanks CFM
    good info, that explains why so many peeps complain about 502's using oil
