Who's got the recipe?
Results 1 to 6 of 6
    Senior Member Nordic78's Avatar
    Tucson
    Thumbs up Who's got the recipe?
    Hotrod56 told me about a 500 Hp BBC recipe that use to be on hotboat. I guess the forum is gone know but did anyone by chance copy or remember it?
    Default Cyclone
    made 730hp at about 6,500 rpm with a 502 and some bolt ons. stock bottom end
    9.6:1 CR
    AFR 315cnc heads
    Comp Cams hydraulic roller cam
    1.7 roller rockers
    Holley 950HP carb
    Edelbrock Victor RPM Air Gap manifold
    msd 6al box
    maybe he will chime in to give you some details, I think Widowmaker did a similar build
    Tri-Cities, TN
    Quote Originally Posted by Nordic78 View Post
    Lots of good recipes but what do you want to accomplish? That's what you need to decide then build to accomplish the goal..
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Senior Member hotbo's Avatar
    lake Ouachita AR
    9.6:1 CR
    AFR 315cnc heads
    1.7 roller rockers
    Holley 950HP carb
    msd 6al box
    6500 will he be seeing this.i would think a 9.5-10.1 with a 750-850 single plan or rpm air gap with a good solid flat tappet cam would get close.
    Newton Ks.
    It would. I should be there with the head work I just had done, and on lousy compressuion ratio. 10:1 would do much better.
    Tucson
    I like it, I will be taking apart the motor next week and getting started. That sounds like a good start/ target, hopefully all will look good when I dig in.
