496vs555 bbc
Results 1 to 14 of 28
496vs555 bbc
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Default 496vs555 bbc
    oaky fellas we are thinking of building a 555 ci mill for our tx-19
    we have a 496 set-up with roughly 700hp.
    here is my main questions.
    1. we have brodix bb2-plus sts cnc fully ported heads.
    will these be sufficient enough for the 555 mill?
    i have already talked to chris about a new cam profile
    it will re-use the brodix intake and the 1050 dominator carb as well.
    what kinda hp gains are we looking at by doing this??
    is it gonna be worth the money?
    any tips or advice will be due noted,thanks travis
    p.s i would like to make as much hp as possible in the lower rpm range 6000-6300rpm range.
    not worth the effort unless you guys plan on building more compression than you have been. my lil 505 4.25 put it on kevins scott shairoff pro built 4.25 stroke 555 last summer , after i got that pump hooking up, he never wanted to race again we were sprayin the same amount, so you can't use that arguement
    I have a set of bb2plus heads on a 557, when I asked(how much to small the heads were), answers ranged from they will be fine to 5400 r's to 6300 r's.
    Needless to say I will be all ears on this one.
    lake Ouachita AR
    kevins mill was fine,his boat was the problem
    lake Ouachita AR
    are yours the cnc ported heads like ours?
    i have heard around 6300 myself
    this will be a pump gas mill like the 496 is.
    no race fuel for the ole man
    he wasn't the only 1 that day 540's ,a 598bbc, couple blown 555's, and the lil 4.25 stroked on by em. stay with what you guys have and just spray the damn thing
    lake Ouachita AR
    tom we are scared toit is a 2 bolt main.he is making around 700 then spray 200 plus on that,im thinking some shits goona come loose,am i wrong
    betta yet, talk your pops into dropping compression and let's stick a hairdyer or 2 on it, we'll get mark to fab up some headers
    dude, you seriously can't be scared after all i sprayed last summer on a 13 to 1 2bolt with a 450hp shot throw in some new main studs, line hone it and let er eat
    have ole bill watch this and tell him 1400hp on pump gas would be a breeeeeze with that same shortblock
    10 to 1 you could prob make 10-12lbs of boost on pump gas goin thru a good air to water intercooler.
    lake Ouachita AR
    im sorry tom,but niether one of us want any of that alien looking shit hanging off our mills.
    we are just living in the past i guess
    lol, they'll never get close nuff to see any of it it was a big change for billy to go from that injected blown 540 all big/bad looking and shitt but he's a believer now.
    No, mine are not cnc'd. Good luck on the build ...keep us posted.
    lake Ouachita AR
    well we are starting to get mixed feelings over this build.
    just how much more power could we make is the question
    100 plus more hp,we would do it,50-60 not worth the money???
