temp sender
Results 1 to 11 of 11
temp sender
    MD
    Default temp sender
    on a elc. temp sender is it ok to shorten the end that go's into the water/oil
    passage???
    It's about 1/2" long would like to cut it down about 3/16 to 1/4".
    I'm useing it in a oil passage and trying not to block to much of it.
    gen 5 block, going in one of the oil cooler plugs by the pan.
    THANKS
    passage???
    THANKS
    Get a different sender, like a 1/8th NPT sender, and screw it into an adapter, then into the block.
    MD
    I have 2 of the 1/8 senders but thay dont read right and have no# on them.
    Have one with 3/8 npt that reads right.
    I'm going to look tomorrow and see if I can put my oil press. in that hole and put the temp in the hole right above the oil filter pad
    Next time I pull the pan I will weld one in it.
    [email protected]
    Ohio
    I'm thinking maybe screw a short nipple in the hole, screw on a coupler, then the sender?
    Tim
    Senior Member miketeast's Avatar
    maryland
    http://www.egauges.com/vdo_send.asp?Sender=300F_150C
    i forgot what range your gauge was
    Team FTL
    Horsepower Homo
    Centistoke Fag
    The Right Coast/SE-PA
    Just go with the oroginal MikeT strap-on...I did
    MD
    Thanks everyone I got it all figured out now.
    What would I do with out this site
    MD
    I think Rat is the next one in line to get a MikeT strap-on
    Senior Member fat rat's Avatar
    Prince George's County MD
    Last I heard it was on back order............due to supply in demand!
    In thrust..............we trust. Team FTL
    If you don't stand behind our troops, please feel free to stand in front of them.
    MD
    With the MikeT post I found a 1/8th sender, and I have a 3/8th npt to 1/8th bushing that will fit the block. Which is what I had just wrong sender and APITA to get to
    MD
    Quote Originally Posted by fat rat View Post
    Rat the shop is open for you, same story as last time to get in if im not home
