Carb issues?
Results 1 to 9 of 9
Carb issues?
    Junior Member FASTBOATNUT's Avatar
    Default Carb issues?
    Ok pump it 2 or 3 times fires right up runs for 10-15 seconds starts to stall pump it with gas it tries to keep running but spits back threw the carb and stalls!?? any ideas
    adjusted the floats
    adjusted air fuel
    checked fuel pressure
    cfm
    cfm is offline
    If not a carb problem, it could be not enough initial timing. Initial timing can have a huge impact on cold start and running.
    X2 on initial timing. Too much advance will cause a pop through the carb.
    What idle speed do you typically idle at? If you hold the throttle open, then slowly close it, what's the lowest RPM you can set it to without it dying?
    I bought the boat and have only ran it once the first time it was hard starting once it was going had to pump the gas to get it on plane once on plane it ran good! slow it down and stall! it was a pig out of the hole. messed with jetting, advanced timing and still out of the hole having to pump the sh.. out of it once on plane lost 800 rpm and 15 mph???????
    Quote Originally Posted by FASTBOATNUT View Post
    What kind of carb? Pics?
    Senior Member rocket98's Avatar
    Oro Valley, Arizona
    You might check out the gasket on the bowl. If you installed the gasket backwards it covers up the accellerator pump hole. Don't ask how I know this
    Quote Originally Posted by rocket98 View Post
    He never mentioned that it was a Holley. Although the "adjusted the floats" statement kinda points to one.
    Ok new PV and it fired up on the hose in the driveway did some adjustments it runs in the drive ok but I will water test as soon as we have a day without rain! thanks guys for the help I will let you know
    Sounds like the power valve may have been the culprit. Were these problems you were having present on the trailer as well as in the water?
