Jomar's are On...!
Results 1 to 6 of 6
Jomar's are On...!
    The Right Coast/SE-PA
    Thumbs up Jomar's are On...!
    What can I say, excellent fit and finish, quality made (in house) Poly Locks and dealing with Jon Jomar was a pleasure.
    I can honestly recommend this product 110%!
    Just a note...without any spring/lobe pressure this stud girdle fell on. With spring/lobe pressure I then could tell my studs had some deflection. Even with that a good push by hand and on it went.
    How much did it cost? With nuts?
    Senior Member Jim W's Avatar
    Upstate NY, Canandaigua
    Quote Originally Posted by Pw_Tony View Post
    How much with sprinkles????
    Nice looking girdle.
    Jim
    GN7
    Do you guys ever read anything I post, or just go straight for the throat?
    Got it wet on 6/15/10-------->finally......
    E-85 I'm saving the world--->8 thumps at a time
    Call and speak w/Jon Jomar and tell Ray from Philly sent ya
    I've run the Jomar's for the Ford A-460's in the past. They make a great product. Sometimes setting the lash was a bit tricky, but I just had to work my way through it.
    S CP
    Senior Member blown65's Avatar
    Medford Or
    I like mine also, got a set on the BBC and my SBF.
