Roller cam
Results 1 to 14 of 16
Roller cam
    Member bennyb's Avatar
    Mission viejo,ca
    Default Roller cam
    If you were going to go with a roller cam witch one would it be?
    Go on get your ass outa here
    Chris Straub. You can either contact me, or him directly.
    Mission viejo,ca
    Thanks steel, I sent him a email last night. I only have about an hour on this so I guess I did it at break in.
    [email protected]
    Ohio
    Thats the reason I went roller years ago. Figured what I was paying to replace flattened flat tappets I could have a roller. I went with Comp and never had a problem. I hear only good about Straubs cams.
    Tim
    Senior Member CK7684's Avatar
    Minnesota
    I like my Bullet cam...
    I have an aggressive Ultradyne cam I would sell...never been installed...
    Senior Member Hydroguy's Avatar
    How agressive? Roller?
    San Diego, CA
    cstraub.
    Boat 405.
    Cstraub..... He can taylor the cam to your exact needs, expectations have been met, and often exceded with his profiles.
    Minnesota
    Quote Originally Posted by Hydroguy View Post
    I'd have to double check the specs to see exactly, but going on memory, its .701 lift, 244 duration @.050 and 108 LSA mechanical roller for BBC...
    It's still in the box. I bought it for a different application, but then projects changed...
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Chris Straub, he guaranteed me 625-650 HP @ 5800 on my last build. On the dyno it put down [email protected] and peaked at 5900 (but @5800 it made 671.4). I've used him twice now, great guy to work with.
    spokane, WA
    www.smreperformance.com
    E-mail Kim and them them I sent you.
    Travis
    thanks for the info but not as aggressive as the one I'm using now.
    I have a brand new Lunati RRB 308-316 if you're looking for a cam. It's .722 x 2, 272/280 on 108 ICL, 110 LSA.
    Mission viejo,ca
    Thanks everyone for your replys. I found a local builder that took the engine and is doing it. I am in a time crunch as momma said fix her boat now!
    Who am I to argue
