waist gate location
Results 1 to 14 of 32
waist gate location
    sacramento
    Default waist gate location
    any ideas how to make this set-up look decent? the adapters they made look hidious.i want to keep the logs if possible. any better adapter ideas or????thanks ,turbo wogClick image for larger version.
Name:	P1000417 27percent.JPG
Name:	P1000419 27percent.JPG
Name:	P1000424 27percent.JPG
    spokane, WA
    I dont think those look to bad, you will have to keep them in that spot if you want to keep the log's though. I would have made them so they came out the side of the adapter pointing to the outside of the hull. Then point the dump straight up and make a nice pipe with a 90 degree bend in it to dump out the back of the boat with the exhaust off the turbines.
    You could still do this if you cut the existing pipe off flush and get a couple a tight radius 90's!! That will point them to the outsides of the hull then you can build some good looking dump tubes!
    Travis
    sacramento
    thanks! they were supposed to come out the side they told me they were gonna be @1 1/2" tall
    Thumbs up Lookin good Paul!
    Quote Originally Posted by turbo wog View Post
    Those WG's are pretty close to the fiberglass, not sure how hot they will get . . . can you rotate them? Another option could be to add turbo header flange as a spacer but that might change other geometry . . . . fockin turbos!
    Hey sorry I missed your call the other night . . . out workin on the hydro
    sacramento
    Quote Originally Posted by LandSpeedRacer View Post
    hey scott,the adapters are being sent back. they were supposed to come out the side. gotta have new ones madeturbos being sent back too . i'm out for a few more weeks. uness i get some temparary turbos or exaust & run no turbos for now.
    Can you unbolt the elbow and bolt on a over the trans pipe? If so I have a pair that have your name on them (for a Mondelo or three) they are slightly used chrome with a flat flange you can drill if you need to . . . . anything to get Turbowog Racing back out there . . .
    Let me know bro
    sacramento
    Let me know bro
    got any pics? i can pull off the whole exaust for now!
    dammit I missed your call again!
    Call me at work Pauli . . . . .
    Douglas, MA
    I would like to see pics of this too!
    Senior Member s2k1's Avatar
    Even though they are redoing them for you, you could make them look a little cleaner. Although, I don't think they look bad.
    For a cleaner look, have them weld the nuts in place, then cap the whole thing with sheet metal. This way it will look more similar in size to the logs that they are coming off of.
    Chris @ Benchmark Performance
    sacramento
    Quote Originally Posted by s2k1 View Post
    thank you s2k1. thats what i thought. not very clean at all right now. i want them built out of a solid peice of aluminum, but the seat for the waiste gate is stainless. i wonder if they can braze alum. to stainless?
    Jet Hot (or similar) coat the riser/wastegate housings and they will hardly be noticable when it is all done.
    okie, lake Texoma
    Default wastegate adapters
    I dont know how much you can tell from this old pic, but here are the ones that an old friend of mine wittled out of stainless, he has since passed away, sure do miss 'em he was a great guy and a hell of a machinist.
    sacramento
    thanks has do you know if that is a solid piece of ss or like a tube with a inner tube?
