Carb problem?
Results 1 to 14 of 18
Carb problem?
    LF2
    LF2 is offline
    OC
    Default Carb problem?
    Had a problem this weekend at the river. Boat runs fine above 1800rpms but after a cruise when I slow down below 1800rpms it loads up doesnt want to idle blows black smoke then would die and wont start until it sits for awhile(flooded). I pulled the sight plugs after it died fuel came out of front one, after I finally got it restarted I checked float levels seemed close but I adjusted it down a little anyway. ran the boat again when I slowed down did same thing would not idle, black smoke, etc. so i pulled sight plugs again front one had fuel coming out. Again after finally getting it restarted pulled sight plug and it was below hole.
    Today i pulled that bowl off everything is clean inside needle &seat move freely.Carb is new only 3rd trip, ran perfect last two trips, fuel pressure is at 6.5psi carb is holley 850dp any thoughts on what it could be.
    Based on your post above, if I were to guess I'd say bad needle & seat maybe (needle not seating for some reason)? Does your fuel pressure hold constant as you increase RPM?
    LF2
    LF2 is offline
    OC
    i did not check the fuel pressure while running did not think of it since it ran fine above 1800rpms. the needle & seat were replaced with the all metal ones when I jetted the carb.
    Quote Originally Posted by LF2 View Post
    Mechanical or electric fuel pump? Internal or external regulator?
    LF2
    LF2 is offline
    OC
    holley electric fuel pump (gen v block) with external regulator.
    Another thing I'd check is the float itself...could be a slight leak in it not allowing it to float.
    Kingman/Golden Vly, Az
    how about the power valve?...i think a bad one could cause that condition!...not sure tho
    FastRat
    FastRat
    One thing a blown power valve WOULDN'T cause though is the bowls overfilling.
    With no viton tip on the needle?
    LF2
    LF2 is offline
    OC
    Is that the black tip? if so then no they are all metal.
    If you have a friend with a carb would let you try to see if its carb related.
    Quote Originally Posted by SS 201 View Post
    I believe he stated that only the primary bowl was overfilling itself...how can that NOT be carb related?
    What i meant instead of all the suggestions try a carb to see whether this problem would be corrected. Rhen move forward, why waste time.
    Newton Ks.
    Ditch the plain steel needles and get the good ones with the viton tips.
    According to my Holley Manual (disclaimer for the Jetaholic fans) the steel plain needles are intended for "alternate fuels", aka Alcohol and Nitromethane, not gasoline.
    Metal parts, without a rubber/flexible non-metal seal surface will be nearly impossible to get to seal properly.
    I would actually be not the least bit surprised if this setup is flooding at idle/near idle.
    H.L. Mencken
