Synchronic waste gates
Results 1 to 8 of 8
    spokane, WA
    Default Synchronic waste gates
    Thought some of you may like this vid and some of the reading up on these.
    Travis
    Vid
    How it works
    Pressure demo
    Yucaipa Ca
    So sexy on the 2 step.......
    Senior Member s2k1's Avatar
    Thanks for the links. I guess I am out of the loop. I didn't even know about these guys.
    Chris @ Benchmark Performance
    spokane, WA
    It may take a lot longer in the boat scene but turbos will rule the world someday in evey aspect of racing.....
    Travis
    p.s. this post is more for fun and nothing else so I do not get slamed to hard by chris....
    sacramento
    how are the 50mm turbo smart waist gates? i noticed it is anodized stainless valve but not incolnel.is this ever a problem?wot long runs, diaphram failure?
    spokane, WA
    My 60mm gates I have now are Stainless Valves and The 40mm Tial that was on my mustang I believe was stainles as well.
    Travis
    okie, lake Texoma
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    Vid
    How it works
    Pressure demo
    Now lets see that vett turn the boost down to 2 lbs and run wfo on 87octain, this would be more of a demo. of the capabilities of the gates.
    The more boost you intend to run, the less you'll be asking of the waste gates. That vett is running a sh-t load of boost and "could" probably get away with an even smaller set of gates.
    our ebay special wastegates will go all the way down to 2lbs
